bolts to pipes on BB HP exhaust manifold
#249342
03/10/09 10:30 AM
03/10/09 10:30 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
what's the correct bolt size to join exhaust manifold to pipes ?
head, bolt lenght and diameter, and thread.
Re: bolts to pipes on BB HP exhaust manifold
[Re: RapidRobert]
#249344
03/10/09 11:26 AM
03/10/09 11:26 AM
NachoRT74
Valencia, España
wow!!! 3/8 diameter 9/16 head ? I have actually 11/16 bolt head mounted on ? dunno the diameter, I'm not good on that, but bolt allmost fill completelly the exhaust hole.
that would left LOT OF ROOM between hole and bolt!!!
I guess grade 8 ?
[Re: Classof70Chally]
#249347
03/10/09 01:15 PM
03/10/09 01:15 PM
NachoRT74
Valencia, España
the problem is 11/16 bolt heads dosn't allow to fit the wrench ( with closed side of wrench ) on top to hold the screw for a while you are tighten the nut.
maybe if I get 5/8" head bolt will be in the middle of the line ?
I wanted to get filled the hole to a propper aligment of pieces, but!!!
Or maybe grade 8 fine thread ( I think mines are larger thread ) will get less damage on head with holding with open side of wrench with 11/16 head ?
The advantage on use the closed side of wrench, is they hold by themself on place for a while I tight the nut.
#249349
03/10/09 09:58 PM
03/10/09 09:58 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I just did this fight last summer, I had 3/8 dia bolts in it and it leaked..so, I replaced them with 7/16th bolts.. But in reality the true problem was one of the pipes was not bent correctly and was hitting the torsion bar or bellhousing causing the misalignment. I had to have new pipes made to correct the problem. I used gr 8 bolts and nuts.. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: RapidRobert]
#249350
03/11/09 09:45 AM
03/11/09 09:45 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
what's the correct bolt size to join exhaust manifold to pipes ? head, bolt lenght and diameter, and thread.
(1) 9/16(pretty sure) (2) dont know (3) 3/8" (4) 16 tpi(coarse)
Incorrect, the CORRECT size for BIG BLOCK exh manifold to fipe is a 7/16-14 bolt . as far as asking the bolt head size ??? The only come one way , the nuts though can be either 5/8 or 11/16"
