Request for help - B or E-body V8 k-frame mount pad width
#2492918
05/06/18 08:58 PM
05/06/18 08:58 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
I bought a set of Arruzza hemi engine mounts from a member here a few years back. My engine was already in with a set of Schumacher mounts. And its a bit of a chore to pull the engine to swap the mounts, but I knew I be into it in the future. Well, the future is now. I had to drop the trans for a rebuild, and drop the TTi's to get the trans down. So the car is on a lift and the engine is supported with a bar. I pulled the driver side mount and tried to test fit the LH Arruzza mount on the pad. No go. By 1/4 inch. The seller made it a point to say he bought them, attached it his engine, but never mounted it to a k-frame.
Hoping to find somebody with an B or E-body k-frame without an engine on it.
**Would someone measure the pad width on their B or E-body V8 k-frame LH side where the bolt goes thru?** Then I can compare it to my mount width. It'd be a huge help to me.
Re: Request for help - E-body V8 k-frame mount pad width
[Re: Vert]
#2493065
05/07/18 03:33 AM
05/07/18 03:33 AM
RapidRobert
It might be several days before I can get back over there but I wrote myself a note to measure it.
[Re: Vert]
#2493718
05/08/18 06:51 PM
05/08/18 06:51 PM
RapidRobert
2&3/4" across/front to rear/above the bolt hole
[Re: Vert]
#2495871
05/14/18 10:55 AM
05/14/18 10:55 AM
Vert
Annapolis, MD, USA
So the mounts I bought appear to be like the Arruzza mounts except .2in narrow. Tried spreading the mounting ears, but warps the backing plate, and moves the location. I'm convinced they are fakes. I don't trust the passenger side to be correct at this point.
So I've tried for a week to call John Arruzza using the two phone numbers I have. No luck so far. Anybody talked to him recently? I'm ready to throw my cash at him. Else my choices are back with the Schu's, or buy a hemi k-frame and mounts, or go Alterkation or similar.
[Re: Vert]
#2496793
05/16/18 11:04 AM
05/16/18 11:04 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
Yep, Aruzza has retired or at least gotten out of the car business. He went off the deep end w/ a rant/prediction about the end of the world a while back.
[Re: Vert]
#2496794
05/16/18 11:07 AM
05/16/18 11:07 AM
an8sec70cuda
I actually have a set of what are supposed to be Aruzza hemi conversion mounts on the shelf. Bought em from a member here a few years ago. Not for sale, need em to put the hemi in my dad's road runner. I can take a measurement to compare to yours if needed? Just let me know exactly what you need and I'd be happy to help.
[Re: Vert]
#2497910
05/19/18 04:59 PM
05/19/18 04:59 PM
an8sec70cuda
That'd be awesome. Can you measure inside width of the ears on the solid mount? And distance from front ear to edge. Stuff I have marked in green. Thanks much. Between the mount ears is about 2.750". The edge to the mount ear is 1.300". I measured the width of the mount on an old '69 road runner k frame and its about 2.710". Hope this helps.
