Re: Torque Converter
[Re: scarly10]
#2493215
05/07/18 02:57 PM
05/07/18 02:57 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Its probably higher than 3k stall if you can stage it at 2500. A convertor is pretty much a convertor. Send it out to any competant shop and have it freshened up if thats what it needs If your running what you want to run with it doesnt seem like you need a new one.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
