Re: Best way to install a upper door hinge spring
[Re: Sammy]
#2493076
05/07/18 05:11 AM
05/07/18 05:11 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is how it's done with the spring in a vise.
1. Clamp bottom of spring with hinge loosely attached. Photo is S shaped spring, but C shape should be similar.
2. With one hand use a large crescent wrench or similar to turn the spring from relaxed position A to stressed position B. The force needed is maybe about 30 ft lbs or so.
3. With other hand raise hinge to hook the spring in stressed position.
