Degree cam Question--Stock Style 440
#2492553
05/05/18 09:35 PM
05/05/18 09:35 PM
Posts: 145 Chicagoland 'Burbs
SlickRS23
Chicagoland 'Burbs
Hello, Was in the process of degreeing in my cam, a Comp Cam Extreme Energy Hyd.268 and new Comp Cams magnum timing set with 3 keyways cut in the crank gear. I am using the 0 degree keyway, and after degreeing the cam a few different times, I keep getting 104 degrees. Comp Cams calls for 106 degrees and I know 1 degree wont hurt but what about the 104 I get? Is this worth fussing over? My car is a street driven'70 GTX with a 440, TRW Six-pack pistons, stock heads, stock torque convertor and 4.10 gears. Any comments and suggestions are appreciated. Thanks, Jeff ![](https://i.imgur.com/rhDQ8arl.jpg)
Re: Degree cam Question--Stock Style 440
[Re: SlickRS23]
#2492556
05/05/18 09:45 PM
05/05/18 09:45 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Are you using a hydraulic lifter to degree it in.
[Re: pittsburghracer]
#2492563
05/05/18 10:05 PM
05/05/18 10:05 PM
SlickRS23
Chicagoland 'Burbs
Thanks for the replys Are you using a hydraulic lifter to degree it in. Yes, I am positioning the indicator tip on the top edge of the lifter body
[Re: SlickRS23]
#2492625
05/06/18 12:40 AM
05/06/18 12:40 AM
RapidRobert
You are 2 deg advanced from their recommendation which I would assume is advanced a certain # of degree from the LCA (tho I'm a bit rusty on cam tech). Agreed, run it & see how it acts & work from there & retard it as needed. I'm assuming you've checked P/V clearance etc & as said you want NO pinging (not even slight) no matter what. & I cant hear mild pinging but my buddy can.
[Re: SlickRS23]
#2492666
05/06/18 03:31 AM
05/06/18 03:31 AM
Posts: 43,317 Bend,OR USA
Cab_Burge
I would, and do on every cam I degree, try checking the intake lobe center at three different lifts, .200,.100 and at .050 before and after max lift to see if it changes from 104 to 105 to 106 ILC. Once you see what results are from that take the time to check exhaust lobes at the same three different lifts, if it mimics, duplicates, the ILC results your going to have to decide if you want to run it or change it ![work work](/ubbthreads/images/graemlins/custom/work.gif) If it changes to 105.5 or 106 on the ILC I would run it, if I checks the same on all three locations then go from there
[Re: SlickRS23]
#2492717
05/06/18 10:58 AM
05/06/18 10:58 AM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
I'll start with the assumption that this is 99.9% street car, and your goal is for it to run as well as it can. Understand that run as well as it can might actually mean different things to different people.
First understand that there is nothing magical about 106°. It is nothing more than a safe recommendation from Comp Cams. It will generally work well in most cases. The reality is that no body knows with certainty what will be the best in you car.
It will run well at 104°. It will be very crisp with light throttle at lower speed. Street guys generally like this better. There is absolutely nothing wrong with 104°.
However, if it were mine, I would do it different, and vastly different than conventional wisdom on this forum. With a cam that size, your compression, and a 4.10, I would put it in at 108° or even 110°. The throttle will not be as crisp, but the car will probably be faster, IMO.
Like someone said, a new chain will stretch and it will back the cam up at least 1°.
Now you'll just need to figure out where you want to put it.
[Re: SlickRS23]
#2492740
05/06/18 12:06 PM
05/06/18 12:06 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
An advanced centerline will give you more lower end torque and throttle response. A retarded center line will give you more top end charge. As far as detonation, that can be worked out with thermostat temperature, spark plug heat index, octane ratings, timing curves. But in all reality, 2 degrees on a street car will not have an overwhelming change in engine characteristics. If it bothers you that much, though, that you want it at 106, you could buy an offset bushing kit, drill out the gear and put a 2 degree bushing in it. I stake the gear to keep the bushing from coming back out when I am done.
[image][/image]
[Re: SlickRS23]
#2492748
05/06/18 12:14 PM
05/06/18 12:14 PM
fast68plymouth
So. Burlington, Vt.
However, if it were mine..........With a cam that size, your compression, and a 4.10, I would put it in at 108° or even 110°. I would have been targeting 108-109 in that combo......... And it's still likely to rattle on hot days.
[Re: BSB67]
#2492750
05/06/18 12:31 PM
05/06/18 12:31 PM
RapidRobert
With a cam that size, your compression, and a 4.10, I would put it in at 108° or even 110°. The throttle will not be as crisp, but the car will probably be faster, IMO. would that be cuz the midrange/high end would gain it back? (& then some).
[Re: fast68plymouth]
#2492755
05/06/18 12:37 PM
05/06/18 12:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont know what your true compression is.. I dont see where it was stated with these heads.. but I always try to advance the cam on a street car so it has better grunt on the low end.. do you know your compression.. did you measure it ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: SlickRS23]
#2492760
05/06/18 12:56 PM
05/06/18 12:56 PM
fast68plymouth
So. Burlington, Vt.
I did some heads and supplied the cam for a similar build a few months ago. I used a cam that was 279/287, 227/235@.050, .480/.490, 113lsa, installed at 109. Stock type 906's set up for proper quench using KB quench done pistons, along with the bowls and short turns reworked(flow 256/182@.500).
This combo was getting run with ex manifolds, which was a big driver in the cam choice.
[Re: SlickRS23]
#2492787
05/06/18 01:45 PM
05/06/18 01:45 PM
fast68plymouth
So. Burlington, Vt.
I like that Crower 271 cam, ran one myself in a mild 440 years ago. Good power and good manners......... But I have heard from a few customers who used one that had some detonation issues with it. I feel a 440 can tolerate a bit more seat timing than 271, and I like the fact that the Thumper lobes aren't particularly fast(or noisey).
That particular grind I use has made 460hp(on ARC's SF-902 dyno)from a quench dome pump gas 446-6 with ex manifolds with 906 heads that were slightly better(more rework) than the ones that went on this last build.
That being said, I don't feel there's anything magic in that cam, and I'd expect similar results from just about any similarly sized cam.
[Re: SlickRS23]
#2493226
05/07/18 03:08 PM
05/07/18 03:08 PM
Posts: 5,167 CT
GTX MATT
CT
Mine was 104.5 when assembled, had it apart a few thousand miles later and checked it and it was 106.
Whatever you do, be careful with the +/- 4 key ways, mine was really +/- 8 from 106, so in reality your straight up is +4, your +4 is +12, and your -4 is -4. If yours is the same you will need another timing set for any other setting, and those chains have slots instead of holes for the cam dowels so you can't use a bushing.
I would recommend checking your +/- 4 key ways while you have the engine out so you'll know what you're up against if you want to change it later.
