Re: Grease exiting green bearings [Re: Mr340] #2492699
05/06/18 10:12 AM
05/06/18 10:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My green bearings lasted through 12 or 15 years of street driving and drag racing before I had one start to make a little noise. I wouldn't sweat driving them on the street.
I always ran inner axle seals on my 8.75 but on the Dana I just built the moser housing ends don't set the seal deep enough to fit, i guess I will find out how much impact the seal has on bearing life.
68 Barracuda Formula S 340
Re: Grease exiting green bearings [Re: Mr340] #2492817
05/06/18 03:34 PM
05/06/18 03:34 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Is your axle tube vent clogged? A clogged vent plus heat is the only thing I could think of that could create pressure buildup inside the housing to push the axle bearing grease out like that.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Grease exiting green bearings [Re: rumblefish72] #2493098
05/07/18 09:45 AM
05/07/18 09:45 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Good thought, I'll check it out.
I installed another center section i had(4.30 w/ clutch sure-grip), cleaned everything up,put the axles back in and took it for a ride. Everything sounded good, noise gone. I will drive it a bit and check the axles again, but rite now they seem fine. up
