Tach goes crazy and engine starts missing #2491376
05/03/18 11:23 AM
05/03/18 11:23 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I will be driving along and the engine starts missing and the needle on the tach will go from 3000 to over 6000. The tach is all over the place while the engine misses even though the rpms dont really change. I am running a mopar electronic distributor with the chrome ignition box. The box is about 10 years old now. I dont know what to try first.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491388
05/03/18 11:43 AM
05/03/18 11:43 AM
bad coil
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491411
05/03/18 12:24 PM
05/03/18 12:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sounds like pick up, although they usually either work or they don't. Swap in a known good box would be the second choice. Look at the wiring for damage or shorts.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491422
05/03/18 12:34 PM
05/03/18 12:34 PM
central il.
second 70 Offline
second 70  Offline
central il.
I had that happen with a msd system and the tach was bad. First and easiest check just take the tach wire off the coil and see if it quits.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491440
05/03/18 12:56 PM
05/03/18 12:56 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Sounds like a ground wire issue. Try running a ground wire from engine to body. I had the same problem, but I forgot to hook up a ground wire from my intake to the firewall.
Hope this helps.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491506
05/03/18 02:40 PM
05/03/18 02:40 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Thanks for the help. Sounds like it could be about anything. I guess i will just start with the easiest thing first. Start swapping in one part at a time until i figure it out. Its been 25 years since i put it together so anything could be bad by this time.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491516
05/03/18 03:03 PM
05/03/18 03:03 PM
an8sec70cuda Offline
Hopefully you aren't still running the factory ammeter/ampmeter in the car? If so, it could be going bad b/c when mine went, that's how it started...right before it burned up the wiring harness.
Also seen a bad tach cause weird misfiring issues. Unplug it and try.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491528
05/03/18 03:23 PM
05/03/18 03:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Disconnect the tach first and try it... thats
the easiest thing
wave
Re: Tach goes crazy and engine starts missing [Re: MR_P_BODY] #2491559
05/03/18 04:16 PM
05/03/18 04:16 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
When this happened to me my first thought was bad tach. Disconnected it at the coil and the ignition was back to normal. I was ready to pull the trigger on a new tach when it occurred to me that there was also a rev limiter connected to the same wire. Unhooked it and hooked The tach back up. Yeah it was the rev limiter.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2491822
05/04/18 07:25 AM
05/04/18 07:25 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Just posted this a few days ago on this thread
https://board.moparts.org/ubbthreads/ubbt...tml#Post2233534
Sounds like a lot of MSD Coils are failing lately from the research I did the last few days
Had my new 432 Stroker on the road the other day for the first time in over a year
Cruising on the highway after about a hour the engine started missing at high rpms
Turned around and headed home , where it started getting worse even at lower cruise
What I first noticed was the tachometer needle was bouncing all over the place , had a mind of its own
Went to touch the MSD 8202 Red Coil checking the tach wire , was super super hot
Just swapped in a old Mopar Resto coil that I had laying around along with a .8 resistor
Ran it for a few hours problem solved
This MSD 8202 Coil I had for about 5 years , ran fine with MP Chrome ECU , MP Distributor prior
First day with the new motor , had me wondering now what - The Tach issue was the only thing that pointed me directly to the coil
Anyways , this MSD 8222 Epoxy Coil - Better ? Same ?
Is there a better coil in factory location bracket on aluminum intake ?
Or is it time for a FBO Upgrade or Rev n nator Upgrade for this new motor
Street Use
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Tach goes crazy and engine starts missing [Re: dirt] #2492036
05/04/18 03:34 PM
05/04/18 03:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I can see an internal short or failure causing that, if the tach signal is being picked up right at the coil primary terminal and not the port at an MSD box.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2492263
05/05/18 01:20 AM
05/05/18 01:20 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
This is what I had happen back in the 80's with my Fiero GT. same symptoms . 1 spark plug wire had a crack and for some reason every once and awhile it would start throwing sparks to the block making a miss and screwing up the tach. Took a while to figure it out but a change of wires did the trick.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2492283
05/05/18 02:25 AM
05/05/18 02:25 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I agree with disconnecting the tach first,no parts needed.Then checking plug wires and beyond.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2492284
05/05/18 02:25 AM
05/05/18 02:25 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What engine are you working on BTW?
Re: Tach goes crazy and engine starts missing [Re: RTSrunner] #2493015
05/07/18 12:44 AM
05/07/18 12:44 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Working on a 70 dart with a 340. It has a mopar performance electronic ignition conversion kit. I finished it in 1993. It rained this weekend so i have not had a chance to work on it anymore. I did replace the ignition box, resistor and plug wires about 10 years ago but everything else is from 1993.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2493027
05/07/18 01:17 AM
05/07/18 01:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
10 years is a long time for plug wires.. since
it was raining out I would look under the hood
in the dark and see if the spark is jumping
under there.. but I would start with wires
wave
Re: Tach goes crazy and engine starts missing [Re: dirt] #2493193
05/07/18 02:14 PM
05/07/18 02:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Use a spray bottle with water in it and spray a fine mist on the wires after dark. You'll find out pretty quick what condition the wire insulation is in.
Re: Tach goes crazy and engine starts missing [Re: dirt] #2499365
05/23/18 09:36 AM
05/23/18 09:36 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I unhooked the tach and it didnt help. So i changed the coil and noticed a plug wire loose on the distributor cap. It runs fine now but i am not sure if i made the plug wire come loose while i was messing with it or not. Either way it seems ok now.
