Re: 426 Hemi head bolt question
[Re: R/T1968R/T]
#2490476
05/01/18 03:02 PM
05/01/18 03:02 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
Also, good luck torquing the head stud nuts upside down in the lifter valley area. I had to buy a special 3/8" drive short handle torque wrench with swivel head to properly tighten those stud nuts. I would lend you mine if you lived closer.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
[Re: RSI700VIPER]
#2490493
05/01/18 03:25 PM
05/01/18 03:25 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Regarding the studs in the lifter valley - You could do like a few long time hemi builders told me...grab a normal box end wrench and crank down on em. Has worked fine for me.
[Re: Cab_Burge]
#2490594
05/01/18 06:52 PM
05/01/18 06:52 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I use a offset socket extension with a lever on it from the square 3/8 end with a box end on the other end( I have three of them,5/8,9/16 and 1/2 socket size) you need to do the math to correct for the extension though None of them are exactly the same length either I did something similar. I found an old box end wrench in some of the old tools my grandfather had. It was a lot thinner around the outside and I was worried it would snap, but fit over nut and cleared the block. I used 1/2" drive torque wrench. Did the math to see what the indicated torque should be to put proper torque on the nut. Sort of pain to hold everything, but better than guessing.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: R/T1968R/T]
#2490756
05/02/18 02:21 AM
05/02/18 02:21 AM
Posts: 15,805 Jefferson State
srt
ESYC
ESYC
Jefferson State
I have the correct tool (torque adapter) to tighten them, I was just curious over the washers. thanks guys!! Is it this one that is like a crowfoot? Is there a torque adjustment factor when using it, or are the published torque values include it's use??
[Re: srt]
#2490767
05/02/18 03:32 AM
05/02/18 03:32 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
[quote=R/T1968R/T]I have the correct tool (torque adapter) to tighten them, I was just curious over the washers. thanks guys!! Is it this one that is like a crowfoot? Is there a torque adjustment factor when using it, or are the published torque values include it's use?? [/quote I couldn't remember the Crowfoot name That is the tool I use You should do the math to reduce the torque setting on your wrench so you don't over tighten the bolts or nuts you use that on I may have it, the formula, written down in the shop, I copied that information out of a Motors or Chiltons manual years ago If I can remember and find it in the morning I will try to remember to post that formula on here if some else hasn't already done it by then
[Re: R/T1968R/T]
#2490927
05/02/18 03:32 PM
05/02/18 03:32 PM
Posts: 2,657 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm assembling a 426 for a friend. He gave me all the head bolts and washers. I thought the 1/2 washers were used only on the studs, but there are 16. Are these extras? HELP!! They aren't extras. It's not a wedge. Hemi's have washers. They should be for 7/16" not 1/2".
2011 Drag Pak Challenger
[Re: rickseeman]
#2491093
05/02/18 08:48 PM
05/02/18 08:48 PM
Cab_Burge
I'm assembling a 426 for a friend. He gave me all the head bolts and washers. I thought the 1/2 washers were used only on the studs, but there are 16. Are these extras? HELP!! They aren't extras. It's not a wedge. Hemi's have washers. They should be for 7/16" not 1/2". he is talking about the 7/16 scallop head stud washers that fit under the boss for the heads studs, not 1/2 inch head bolt washers, I think anyways
[Re: rickseeman]
#2491488
05/03/18 02:18 PM
05/03/18 02:18 PM
Posts: 736 New York
R/T1968R/T
New York
Yes thats exactly what I meant...they look like a crescent moon.
[Re: R/T1968R/T]
#2491579
05/03/18 04:40 PM
05/03/18 04:40 PM
rickseeman
Stuttgart, Arkansas
The washers under the rocker arm head bolts are a little thinner and also have a notch out of them. And then the eight lower head bolts have a thicker washer with them. What was getting at is all the head bolts have washers on a hemi.
