Re: Milodon BB Gear Drive Assy 13000
[Re: Dave Hall]
#2490487
05/01/18 03:14 PM
05/01/18 03:14 PM
Posts: 580 Livermore, CA
Dduster
Livermore, CA
I have one running in my Challenger since 2005. Dialing the cam can be a head scratcher but performance has been excellent! Dave,... what is the difficulty in cam dialing? Is it tough/difficult to install the cam from the get-go? Lack of geometry gradations/lines, no dots or markings similar to Cloyes?
[Re: Dduster]
#2490591
05/01/18 06:42 PM
05/01/18 06:42 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
I've used all three brands of the better 3 gear BB-426 hemi gear drives, Milidon, KB and Donovan. I don't remember the Milidon part number though None of them had any dots on them so dialing in the cam was not as easy as starting with aligning the dots I start off with the cam pin located about where 4.00 O clock is on a clock face with #1 piston at TDC and went from there, I mark the crank and cam gear by a tooth with a etching pin tool also before starting , make sure and write everything down so you know which way to move the cam gear on the cam hub to get the LSA where you want it also
[Re: Dduster]
#2490738
05/02/18 01:28 AM
05/02/18 01:28 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
The milodon in my heap is 35 years old.I had to replace the crank gear.I wore it out! Gave the dial indicator a work out!!
[Re: '72CudaRacer]
#2490749
05/02/18 01:45 AM
05/02/18 01:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Cant help with the BB one but I am building my second small block right now.. both are KB.. love them.. pretty simple to set up.. I set the crank to 107* then slide the cam into top on the intake center line.. then check it again to make sure then side the idler on.. done
[Re: Dduster]
#2490869
05/02/18 01:06 PM
05/02/18 01:06 PM
Posts: 2,668 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I hate to admit the problems I have degreeing in an adjustable timing chain because it would make me look dumb. But with a gear drive following Milodon's instructions it's monkey simple. You just set the cam where it says and slide the gear on. As the commercial says, it's so easy a cave man could do it. The only thing I don't like is all the Milodons I've had used 5/16" dowel pins. This is a hassle. KB used to sell 1/4"-5/16 dowel pins to make this easy but now they're gone...
2011 Drag Pak Challenger
[Re: sgcuda]
#2490973
05/02/18 04:42 PM
05/02/18 04:42 PM
hemi-itis
Do you still need a thrust button when using a gear drive or is it already pinned in place? I still use the white nylon
[Re: Dduster]
#2491136
05/02/18 10:18 PM
05/02/18 10:18 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Thanks, hemi-it is. Not sure what I am going to use on my new motor. A Jesel belt drive would be nice, but so expensive. I was always under the impression that a gear drive is too hard on the valve train, but more and more, I hear that was just an old wife's tale.
[image][/image]
[Re: sgcuda]
#2491168
05/02/18 10:58 PM
05/02/18 10:58 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Do you still need a thrust button when using a gear drive or is it already pinned in place? On my Milodon gear drive the cam thrust button is made on the cam gear cover and on the cam adapter hub. I just installed a new Milodon gear drive on a customers engine and it's still made that way. It also comes with a Torrington thrust bearing that fits between the block and the cam adaptor. Brian
[Re: sgcuda]
#2491242
05/03/18 12:52 AM
05/03/18 12:52 AM
Cab_Burge
Thanks, hemi-it is. Not sure what I am going to use on my new motor. A Jesel belt drive would be nice, but so expensive. I was always under the impression that a gear drive is too hard on the valve train, but more and more, I hear that was just an old wife's tale. I remember hearing the same noise about gear drives years ago, probably invented by some hater that couldn't afford one AKA aside, one point was the lash on the gears was the possible problem by causing "harmonics" in the valve train Me thinks weak valve springs where the problem all along, not the lash
