Edelbrock 1406 flooding the motor...ideas?
#248947
03/09/09 09:22 PM
03/09/09 09:22 PM
Posts: 649 Davis, California, USA
MrBelvedere2
Ok, i recently put an edelbrock 4 barrel intake, 1406 600cfm carb wth electric choke, and a new edelbrock fuel pump on my 1956 belvedere wth a basically stock 361 motor. I ordered everthing brand new from summit. i routed the fuel line got everything hooked up, it ran for a minute then died. It will not start and you can smell gas. I pulled the plugs and it flooded the motor pretty good. I keeps doing this. I checked the float level and the floats to see if they were cracked and letting gas in but they look fine. It pretty much is flooding the motor out after a couple cranks....I'm lost for ideas, anyone been through this before? fixes? thank you for any help you can provide.
1965 Plymouth Belvedere II hardtop
Re: Edelbrock 1406 flooding the motor...ideas?
[Re: MrBelvedere2]
#248948
03/09/09 09:29 PM
03/09/09 09:29 PM
RapidRobert
Eddies cant take excessive pressure(what's your pumps' psi?) or debris in the gas getting by the filter. Float level is a 7/16" drill bit under the float at the outer end(gasket in place)
[Re: MrBelvedere2]
#248949
03/09/09 09:31 PM
03/09/09 09:31 PM
Posts: 3,911 Oregon
hooziewhatsit
My initial thought is too much fuel pressure. IIRC, 5.5psi is what they recommend as a MAX pressure.
[Re: MrBelvedere2]
#248951
03/09/09 09:40 PM
03/09/09 09:40 PM
RapidRobert
Can you R&R your stock pump back on & in 10 minutes time you'll know if its a psi problem
[Re: RapidRobert]
#248952
03/09/09 11:12 PM
03/09/09 11:12 PM
Posts: 9,887 USA
CrAlt
USA
Can you look down the carb and see if its pissing gas in to the intake?
Does the engine have vacuum?
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
[Re: CrAlt]
#248953
03/09/09 11:23 PM
03/09/09 11:23 PM
MrBelvedere2
it is getting gas into the intake, it is getting vacuum. should i get some step down the metering rods? should i run hotter plugs? I'm running autolite 85 plugs in it now, they are a couple weeks old but have gotten very wet from fouling out.
[Re: CrAlt]
#248955
03/09/09 11:49 PM
03/09/09 11:49 PM
MrBelvedere2
I can't get it to run so i can't check the fuel squirting in when idling...it just floods out after cranking not very long. I will try cranking it and see if fuel drips in..if it does what does that mean? I read the manual before i installed the carb. thank you for the tips so far.
[Re: MrBelvedere2]
#248956
03/09/09 11:55 PM
03/09/09 11:55 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
I found the 1406 to be two steps rich when new on my mild 360, so going two steps leaner with new rods and jets helped a lot. That said, don't go changing anything on your engine until you finish the troubleshooting. Is the choke working properly? 12v power to the red wire (not from the coil + terminal ![](/ubbthreads/images/graemlins/tsk.gif) )? I'd suggest you install a fuel pressure gauge and deal with the fuel supply first.
[Re: MrBelvedere2]
#248957
03/10/09 12:00 AM
03/10/09 12:00 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Mechanical fuel pump? I don't know if Eddy has an electric.
Sounds like it's bleeding fuel somewhere. Leave the key off and jump the starter solenoid while looking down the carb. If it's dumping fuel you'll see it.
[Re: feets]
#248958
03/10/09 03:03 AM
03/10/09 03:03 AM
MrBelvedere2
yes it is a mechanical fuel pump that is rated at 6 psi. I will try some of those tricks tommorrow and see how it goes...thank you for the advice!
[Re: AdamR]
#248961
03/10/09 03:31 PM
03/10/09 03:31 PM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
I went through this myself, it was a bad needle/seat. The float level was fine, the seat was just was not sealing all the way. You can test it yourself easily, just flip the carb over and try to blow into the fuel inlet. If you can blow into it, it isn't sealing. Yeah sure, it could be fuel preessure, but he claims it is a stock pump. I would also check the float level again, after that, things on the floats get bent easily, and the measurements aren't correct anymore. ![](/ubbthreads/images/graemlins/musik010.gif)
[Re: 4BBodies]
#248962
03/10/09 05:33 PM
03/10/09 05:33 PM
Posts: 6,680 Va. Beach, Va
69superbee383
Va. Beach, Va
Sounds like a bad needle / seat or improperly adjusted float. If it flooded that badly check your oil. Chances are it is contaminated with fuel. Might want to change to oil before you fire it up to save those bearings.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: 69superbee383]
#248963
03/10/09 07:42 PM
03/10/09 07:42 PM
feets
Senior Management
Senior Management
Irving, TX
If you pull the top off the carb, check the floats for pinholes. It's really rare to see it on a new carb but if they fill with fuel they will sink and flood the engine.
[Re: dynamite]
#248965
03/11/09 01:03 AM
03/11/09 01:03 AM
MrBelvedere2
Well I pulled apart the carb, the floats are set right at 7/16 as they recommend. I also tried blowing into the inlet and I COULD NOT blow in to it. So it is sealing right. My conclusion is it has to be too high of fuel pressure, I am going to get a fuel pressure regulator tommorrow and guage and see what happens. I will let you guys know the update tommorrow when I try it out. Thank you for all of the replies and ideas!
[Re: feets]
#248966
03/11/09 01:36 AM
03/11/09 01:36 AM
Posts: 6,516 Santa Cruz, California
Lefty
![](/ubbthreads/images/graemlins/iagree.gif)
A too fat jet or skinny metering rod is not going to dump that much raw fuel in the intake that fast ![](/ubbthreads/images/graemlins/Twocents.gif)
