![](/ubbthreads/images/graemlins/iagree.gif)
I also have the big block clutch fork
I think its a little shorter than the small block fork.
I am running a lakewood housing and pro parts headers. couldnt use the "factory" bellcrank.
Anyway, there is a "special" big block a body adapter that goes onto the stock bellhousing that moves the bellcrank "stud" to locate the bellcrank position so it lines up with an a body location.
I am thinking "Brewers" has ALL the correct parts needed.
In my situation, I just ordered all the big block stuff and then made it work.
As for the "arms" that You changed?
well, I compared several different bellcranks, from different body styles and the arms, were all "clocked" in the same position. The only thing that varied, was the length, or shape of the arms, and sometimes the position on the bellcrank relating to where on the length of the bellcrank they were.
Also, some bellcranks are shorter to make up for big block, verses small block.
Anyway, its relatively easy to re-work a bellcrank. I do know that space is non existant in an a-body! Especially with headers and a lakewood bellhousing!
I probably learned some new cusswords while making my bellcrank work!
![](/ubbthreads/images/graemlins/thumbs.gif)
ALSO...sorry...I just remembered that I also had to beef up the area on the other side of the bellcrank where it goes to the inner fender?
I was getting some deflection and that was causing some shifting problems.
I may be able to take a few photo's tomorrow, if it stops raining long enough.
I have to pull the dart out and turn it around in the garage, so I can rebuild the front suspension.
I envy ALL You guys with 2 car garages or bigger!
![](/ubbthreads/images/graemlins/beer.gif)
