Energy Suspension Leaf Spring Bushing Set super stock spring #2489350
04/29/18 02:14 AM
04/29/18 02:14 AM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
do these fit super stock springs&stock shackles?
http://www.manciniracing.com/enbbodsupsto.html
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: Joesixpack] #2489758
04/29/18 11:24 PM
04/29/18 11:24 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
here is what a year and a half in Arizona has done to my rubber bushings...that is why i am asking if the above bushings will fit
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: Joesixpack] #2489761
04/29/18 11:27 PM
04/29/18 11:27 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
pic of bushings
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: Joesixpack] #2489901
04/30/18 11:39 AM
04/30/18 11:39 AM
moparx Offline
moparx  Offline
it's just a shame there doesn't seem to be any quality rubber suspension items any more, including [supposedly best in quality] moog.
beer
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: Joesixpack] #2489913
04/30/18 12:05 PM
04/30/18 12:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
SS springs are basically A body springs.I have polys in mine on my B body Been years since I ordered them.Rocky
Chrysler Firepower
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: therocks] #2490161
04/30/18 10:37 PM
04/30/18 10:37 PM
IN
ahy Offline
ahy  Offline
IN
Poly bushings (Firm Feel) have held up well for me on a hard driven E. I have never used Energy Suspension parts so I don't know. In general I believe poly holds up better over time vs currently available rubber parts.
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: ahy] #2490273
05/01/18 04:38 AM
05/01/18 04:38 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
A couple yrs ago Big Bad Bee was swapping out the rubber SS spring bushings for an aftermarket set. As I recall, he carved up & pressed out the existing rubber. The aftermarket bushings didn't fit right away. He found a metal collar inside the big eye of the leaf spring. Once he pressed out the collar, the aftermarket bushings went right in.
You'll have to ask him (Lindy) what brand of aftermarket bushings he used & if he is happy with the feel of the suspension.
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: Joesixpack] #2490489
05/01/18 03:17 PM
05/01/18 03:17 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
The rear shackle bushing on SS spring eyelet require a (7/8 o.d. x 1/2 i.d.) bushing. A-body shackles bolts / shank are .50" and are compatible. I believe B/E use the slightly larger, .5625" or 9/16" shank bolt x 1.0" o.d. bushing. I ran into this issue when I installed SS spring on my E-body.
The kit listed most likely will have the same incompatibility with four of the rear shackle eyelet bushings. Not sure about the large front bushing.
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: Joesixpack] #2490623
05/01/18 08:37 PM
05/01/18 08:37 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Not all Super Stock springs have A body size bushings.
Re: Energy Suspension Leaf Spring Bushing Set super stock spring [Re: Joesixpack] #2490659
05/01/18 10:35 PM
05/01/18 10:35 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Check with ESPO first...
