Page 2 of 3 1 2 3
Re: Wix 51515 options needed [Re: Cab_Burge] #2488860
04/27/18 11:02 PM
04/27/18 11:02 PM
michigan
turbo toad Offline OP
michigan
Originally Posted By Cab_Burge
How about using a remote mounted oil filter to get it out of your way altogether work I like and use the big remote mounted NASCAR race filters, Wix # 51222R with the built in high pressure bypass or the Wix #57400R with full flow with no internal bypass scope
Cab Burge I may be forced to go this route in the future but I'd have to get pretty creative I've run out of room in the engine compartment.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Wix 51515 options needed [Re: turbo toad] #2488864
04/27/18 11:09 PM
04/27/18 11:09 PM
michigan
michigan
I went down to the part store and ordered a 51521. They had a 57035 but it was tiny and yah it would of worked but I wasn't comfortable with the capacity of oil it held.
Re: Wix 51515 options needed [Re: turbo toad] #2488964
04/28/18 09:00 AM
04/28/18 09:00 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I had the same question a while ago and emailed Wix. Can't find the email now. I stuck with 51515, but they said there were two other filters to use that are the same, just shorter.
51521 sounds familiar, but can't find the email now.
Re: Wix 51515 options needed [Re: Sammy] #2488975
04/28/18 10:08 AM
04/28/18 10:08 AM
michigan
michigan
Originally Posted By Sammy
Originally Posted By turbo toad
Originally Posted By max_maniac
5151R it's the WIX race filter
Is the 5151r shorter in size?
NO Turbo, that's full length but filters only 61 microns. Breakin filter 51515 filters like 19 microns but is also full length.
Yes Sammy this is on my twin turbo build I'm in the final assembly stage and realized I need a shorter oil filter to clear everything.
So is the 51515 filter a good one to use for first start up and Cam break in?
Re: Wix 51515 options needed [Re: turbo toad] #2488983
04/28/18 10:44 AM
04/28/18 10:44 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I have ran a K&N oil filter when I couldn't get the wix.. they sell a racing shorty.... actually have done it on multiple occasions and never seem to hurt anything
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Wix 51515 options needed [Re: turbo toad] #2489044
04/28/18 01:09 PM
04/28/18 01:09 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Are there others besides K&N that have a short race filter?
Re: Wix 51515 options needed [Re: RThunder] #2489070
04/28/18 02:22 PM
04/28/18 02:22 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Originally Posted By RThunder
In Fram numbers
The PH8A is the long filter. PH43 is the short filter. Cross reference these numbers. A lot of factory big blocks (most) used the short filter to clear belts, etc
I tossed 3 Fram filters that have sitting on my self for 20 plus years. That is the one filter that I will never run again.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Wix 51515 options needed [Re: Bob J] #2489084
04/28/18 02:55 PM
04/28/18 02:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
[quote=Bob J
I tossed 3 Fram filters that have sitting on my self for 20 plus years. That is the one filter that I will never run again. [/quote]
Those where probably some of the really good, pre 2000, older filters you tossed shruggy
Re: Wix 51515 options needed [Re: turbo toad] #2489085
04/28/18 03:06 PM
04/28/18 03:06 PM
michigan
michigan
Funny how times have changed back in the late 80s early 90s fram oil filters and autolite spark plugs were the weapons of choice for us moparmanics.
Re: Wix 51515 options needed [Re: turbo toad] #2489265
04/28/18 10:48 PM
04/28/18 10:48 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I never had issues with the PH8A. I tried the HP1 filters back in the 80's. I kept sucking the rubber flap in the filter into my oil pump. And that was just a stock pump with the long rotor kits. I went back to the PH8A and never had that happen again. When I was racing regularly, I would change the oil 2-4 times a month, so I went through a lot of filters. PH8A filters never let me down.
[image][/image]
Re: Wix 51515 options needed [Re: sgcuda] #2489302
04/29/18 12:30 AM
04/29/18 12:30 AM
The new ones are really cheaply built now down
Cut one apart and look at it scope
Re: Wix 51515 options needed [Re: turbo toad] #2489346
04/29/18 02:10 AM
04/29/18 02:10 AM
Yes, for the 19 micron fine filtering
Re: Wix 51515 options needed [Re: turbo toad] #2489370
04/29/18 04:16 AM
04/29/18 04:16 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
http://m.wixfilters.com/Search/PartDetail?PartID=157905%20&Source=WESR
http://m.wixfilters.com/Search/PartDetail?PartID=193964%20&Source=WESR
I run the 51068
Used it for break in
Had my A@P Mechanics at work cut it open and inspected the paper
Perfect
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Wix 51515 options needed [Re: turbo toad] #2492826
05/06/18 04:05 PM
05/06/18 04:05 PM
michigan
michigan
I ended up using the 51521 and it gave me what i needed to pass a charge pipe thru that area
Thanks all.
Re: Wix 51515 options needed [Re: turbo toad] #2492893
05/06/18 08:10 PM
05/06/18 08:10 PM
michigan
michigan
Heres a final assembly pic i havent posting any in along time.
Also wheres a good spot to start with on a adjustable oil pump relief valve when priming a new motor?
Re: Wix 51515 options needed [Re: turbo toad] #2492909
05/06/18 08:40 PM
05/06/18 08:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I always pull the intermediate shaft and prime
the engine that way.. just turn the engine over
slowly a few turns while priming
wave
Re: Wix 51515 options needed [Re: turbo toad] #2492913
05/06/18 08:50 PM
05/06/18 08:50 PM
I would prime at #6 TDC compression and #8 TDC compression respectively (to oil both valvetrains). I'd think just about any amount of pressure on the low end would reach all the passages.
Re: Wix 51515 options needed [Re: max_maniac] #2492925
05/06/18 09:30 PM
05/06/18 09:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Check the prices out on this site up
https://www.dieselfiltersonline.com/51515r-wix-engine-oil-racing-filter.html
Almost half Summit Racing price.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Wix 51515 options needed [Re: fourgearsavoy] #2493011
05/07/18 12:37 AM
05/07/18 12:37 AM
Do we, Moparts members, still get the large quanity discount from the wix dealer back east?
If so can someone please post the link again as my computer crashed and I lost all my favorites late last year whiney Thanks in advance up
I need to buy some more Wix filters for shop stock wrench
Re: Wix 51515 options needed [Re: Cab_Burge] #2493029
05/07/18 01:21 AM
05/07/18 01:21 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
https://board.moparts.org/ubbthreads/ubbt....html#Post56314
Page 2 of 3 1 2 3
