Re: Wix 51515 options needed
[Re: Cab_Burge]
#2488860
04/27/18 11:02 PM
04/27/18 11:02 PM
Posts: 368 michigan
turbo toad
michigan
How about using a remote mounted oil filter to get it out of your way altogether I like and use the big remote mounted NASCAR race filters, Wix # 51222R with the built in high pressure bypass or the Wix #57400R with full flow with no internal bypass Cab Burge I may be forced to go this route in the future but I'd have to get pretty creative I've run out of room in the engine compartment.
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: turbo toad]
#2488864
04/27/18 11:09 PM
04/27/18 11:09 PM
Posts: 368 michigan
turbo toad
michigan
I went down to the part store and ordered a 51521. They had a 57035 but it was tiny and yah it would of worked but I wasn't comfortable with the capacity of oil it held.
[Re: Sammy]
#2488975
04/28/18 10:08 AM
04/28/18 10:08 AM
Posts: 368 michigan
turbo toad
michigan
5151R it's the WIX race filter
Is the 5151r shorter in size? NO Turbo, that's full length but filters only 61 microns. Breakin filter 51515 filters like 19 microns but is also full length. Yes Sammy this is on my twin turbo build I'm in the final assembly stage and realized I need a shorter oil filter to clear everything. So is the 51515 filter a good one to use for first start up and Cam break in?
[Re: turbo toad]
#2488983
04/28/18 10:44 AM
04/28/18 10:44 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I have ran a K&N oil filter when I couldn't get the wix.. they sell a racing shorty.... actually have done it on multiple occasions and never seem to hurt anything
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: RThunder]
#2489070
04/28/18 02:22 PM
04/28/18 02:22 PM
Posts: 200 Colorado
Bob J
Colorado
In Fram numbers The PH8A is the long filter. PH43 is the short filter. Cross reference these numbers. A lot of factory big blocks (most) used the short filter to clear belts, etc I tossed 3 Fram filters that have sitting on my self for 20 plus years. That is the one filter that I will never run again.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Bob J]
#2489084
04/28/18 02:55 PM
04/28/18 02:55 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
[quote=Bob J I tossed 3 Fram filters that have sitting on my self for 20 plus years. That is the one filter that I will never run again. [/quote] Those where probably some of the really good, pre 2000, older filters you tossed
[Re: turbo toad]
#2489085
04/28/18 03:06 PM
04/28/18 03:06 PM
Posts: 368 michigan
turbo toad
michigan
Funny how times have changed back in the late 80s early 90s fram oil filters and autolite spark plugs were the weapons of choice for us moparmanics.
[Re: turbo toad]
#2489265
04/28/18 10:48 PM
04/28/18 10:48 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I never had issues with the PH8A. I tried the HP1 filters back in the 80's. I kept sucking the rubber flap in the filter into my oil pump. And that was just a stock pump with the long rotor kits. I went back to the PH8A and never had that happen again. When I was racing regularly, I would change the oil 2-4 times a month, so I went through a lot of filters. PH8A filters never let me down.
[image][/image]
[Re: turbo toad]
#2489346
04/29/18 02:10 AM
04/29/18 02:10 AM
RapidRobert
So is the 51515 filter a good one to use for first start up and Cam break in? Yes, for the 19 micron fine filtering
[Re: turbo toad]
#2492826
05/06/18 04:05 PM
05/06/18 04:05 PM
Posts: 368 michigan
turbo toad
michigan
I ended up using the 51521 and it gave me what i needed to pass a charge pipe thru that area Thanks all.
[Re: turbo toad]
#2492893
05/06/18 08:10 PM
05/06/18 08:10 PM
Posts: 368 michigan
turbo toad
michigan
Heres a final assembly pic i havent posting any in along time. Also wheres a good spot to start with on a adjustable oil pump relief valve when priming a new motor?
[Re: turbo toad]
#2492909
05/06/18 08:40 PM
05/06/18 08:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Heres a final assembly pic i havent posting any in along time. Also wheres a good spot to start with on a adjustable oil pump relief valve when priming a new motor? I always pull the intermediate shaft and prime the engine that way.. just turn the engine over slowly a few turns while priming
[Re: turbo toad]
#2492913
05/06/18 08:50 PM
05/06/18 08:50 PM
RapidRobert
Also wheres a good spot to start with on a adjustable oil pump relief valve when priming a new motor? I would prime at #6 TDC compression and #8 TDC compression respectively (to oil both valvetrains). I'd think just about any amount of pressure on the low end would reach all the passages.
[Re: fourgearsavoy]
#2493011
05/07/18 12:37 AM
05/07/18 12:37 AM
Cab_Burge
Do we, Moparts members, still get the large quanity discount from the wix dealer back east? If so can someone please post the link again as my computer crashed and I lost all my favorites late last year Thanks in advance I need to buy some more Wix filters for shop stock
