setting QA1 springs
#2488516
04/27/18 12:33 AM
04/27/18 12:33 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Got a new set of QA1 2 1/2" id springs for the front for my car. A arm tube chassis set up. I have read a lot of QA1's info but I haven't found how to actually set them up. Some guy's say just snug up the spanner nut and some say screw them up a inch from when the spanner nut makes contact. Anyone know what the proper setup should be?
Re: setting QA1 springs
[Re: rowin4]
#2488688
04/27/18 01:42 PM
04/27/18 01:42 PM
Posts: 11,733 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The shock has a certain installed length at ride height that needs to be maintained. A lighter spring will need to be compressed more than a heavier rate spring to accomplish that. A light spring compressed will store some energy to help get some separation and pitch rotate. Higher horsepower deals won't need the help and will benefit from a heavier spring. The exact rate needed depends on the geometry, shock angle and attachment location, weight on the front end, etc.
