dakota towing #2485165
04/19/18 04:41 PM
04/19/18 04:41 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
has anyone ever tried towing a car and open trailer with a dakota?
Re: dakota towing [Re: bonefish] #2485169
04/19/18 04:45 PM
04/19/18 04:45 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Can’t say I have. But I’ve towed with two suburbans, Córdoba, 72 cutlass supreme, 1976 Dodge van, and three motorhomes.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: dakota towing [Re: bonefish] #2485179
04/19/18 05:04 PM
04/19/18 05:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would hope it's a light car and you're not going far. Need to check your GVWs or you may end up making a DOT cop's day.
Re: dakota towing [Re: bonefish] #2485184
04/19/18 05:10 PM
04/19/18 05:10 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
There is a guy at our local track that has someone tow his 2nd race car to the track maybe 2-3 times a yr with a 4 door Dakota. Open trailer, car prob weights 2800lbs and he drives around 130 mile round trip, guess it does alright....
Re: dakota towing [Re: DusterKid] #2485192
04/19/18 05:34 PM
04/19/18 05:34 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I've towed my challenger with the Dak I had, quad cab 4.7 with 3.55 and towing pkg, WD hitch and brakes on the trailer. i did add heavier leafs on the back. It did fine, some inclines and steeep entrance ramps, you'd have to really give it some gas to get up to speed but it did well.
Re: dakota towing [Re: bonefish] #2485196
04/19/18 05:41 PM
04/19/18 05:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have towed a ton with them, just make sure you don't get going too fast or tailgate anyone as the brakeing is going to take more time. Also a trailer with the weight balanced properly makes a hug difference when you are pushing the limits, car too far forward backwards or side to side can make for adverse handling, the tow rating is a safe limit that will acomadate some amount of improper load, if your really pushing the limits make sure it is centered good, strapped down good and tight and use trailer brakes if you can.
Re: dakota towing [Re: bonefish] #2485197
04/19/18 05:49 PM
04/19/18 05:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Towed many times with a 4.7 4x4 club cab dak. Did very well, better than any of the short 4x4 ramchargers I've had.
Re: dakota towing [Re: bonefish] #2485202
04/19/18 06:02 PM
04/19/18 06:02 PM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
I have a 2000 Dodge Dakota 4WD and I pull my 1970 Dodge Charger on a trailer behind it (trailer + Charger weight about 4700Lbs). Like already stated, the 4.7 engine does not have alot of grunt and the gearbox computer is a little dumb when it comes to change down gears, specially going uphill. My Dakota has added airbags in the rear to keep the rear of the car from sagging.
The Dakota does get the job done, but there are better trucks out there. If I had the money Id buy a "new" diesel Toyota pickup with a manual gearbox...
/Tom
Re: dakota towing [Re: TomsCharger70] #2485211
04/19/18 06:34 PM
04/19/18 06:34 PM
PA.
"Little"John
"Little"John
PA.
The biggest issue is stopping. Pa requires 4 wheel brakes on Trailer over 3000 pounds and brakes must be hooked into tow vehicles brake system to be legal.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: dakota towing [Re: bonefish] #2485420
04/20/18 02:13 AM
04/20/18 02:13 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I towed many miles with my '00 R/T. Good trailer brakes and brake controller are a must. I put rear air bags on, and that was a great improvement.
I also towed with an '06 AWD with the 4.7 HO. I was not impressed with the 4.7, but the truck handled it ok.
Re: dakota towing [Re: bonefish] #2485444
04/20/18 04:25 AM
04/20/18 04:25 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
I sold a Dodge Stealth to a guy who came to pick it up with a 4.7 4 door Dak. I thought, "My Gawd, I hope he doesn't kill somebody." when he pulled out of the driveway. That was mainly because of his trailer. Like some have said the trailer and the brake system is the key. This guys trailer was a POS and he didn't have trailer brakes. His excuse, when I passed shade to him, was, "I'll go slow."
My experience with towing is get the biggest rig with good brakes that you can find but I have towed an E-body shell with parts stuffed inside with a 5.7 Tahoe with trailer brakes just fine. The key is to set anything your towing with up for success and not planning HOPE and CAUTION into the equation. Emergency situations will come into play so plan accordingly. You can tow with anything that can realistically pull the weight but can you stop in an emergency situation? Wheel base and track helps with towing, ride, and handling.
Stock, the 4.7 4 door can tow but don't rely on those stock brakes to do be up to the task. Don't just think about the tow rig, think about the equally important factors like trailer and brakes because the rig is only 1/2 of towing. If you do settle on the Dakota plan the purchasing of a light trailer and trailer brakes because what's behind the ball is the other 1/2. They should be factored into whether a Dakota is capable.
Instagram : @5_points_racing
Re: dakota towing [Re: JP8] #2485485
04/20/18 09:55 AM
04/20/18 09:55 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
thanks for the replys.im really looking at 1500,s but there are so many good deals on dakota,s that i thought i would get some opinions.
Re: dakota towing [Re: bonefish] #2485575
04/20/18 12:57 PM
04/20/18 12:57 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I towed an awd stealth from Detroit to the Pitt area with 2wd 318 96 ram 1500... actually got 14mpg on that trip too. Also 2 more engines in the bed and a pile of parts. Probably in the 6k pound range with trailer. I wouldn't hesitate to tow with one if it's basically flat ground. Too hilly where I live not to have more power and reason I have a cummins now.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: dakota towing [Re: bonefish] #2485580
04/20/18 01:05 PM
04/20/18 01:05 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I live at 500ft and it's 3500ft the two ways out of town.... towing with a Dakota is a pipe dream in these parts.
Re: dakota towing [Re: bonefish] #2485587
04/20/18 01:17 PM
04/20/18 01:17 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Can you --sure, should you , not really but ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: dakota towing [Re: bonefish] #2485769
04/20/18 08:25 PM
04/20/18 08:25 PM
Iceland
BadMoonRacer Offline
Iceland
I have often towed my ´66 Charger on an open trailer with my 4.7 2007 Dakota. Even across mountains. No problems.
Ragnar in Iceland.
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: dakota towing [Re: bonefish] #2485809
04/20/18 09:34 PM
04/20/18 09:34 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I towed my cuda on an open trailer w/my 88 dakota for about 4 yrs. It had the v6 and had 3.91 gears. Did fine, until I hit a large hill. Then even semis passed me.
Ok
Re: dakota towing [Re: cudatom] #2485849
04/20/18 11:05 PM
04/20/18 11:05 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I towed for quite a few years with an 02 Durango 4.7 ,tow pkg ,with 3.92 rear and air bags. Trailer was a 20 ft Haulmark enclosed with my Dart, scooter, tools etc it towed fine went to Indy, Virginia, Pittsburgh etc all pretty long trips and it was good and comfortable. Of course my H.Q.C. tows even better!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: dakota towing [Re: bonefish] #2485871
04/21/18 12:04 AM
04/21/18 12:04 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I would think the area has a lot to do with it. With a light car you'd probably be OK.
In our area of western Pennsylvania, with all the mountains it would be tricky. It isn't the power, it's the stopping power of the trailer truck combo. In our area, a Dakota would be pretty light.
I wouldn't do it.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: dakota towing [Re: Steve1118] #2485935
04/21/18 04:21 AM
04/21/18 04:21 AM
I wouldn't do it.
I wreck a 1968 hemi GTX on a borrow lightweight two axle trailer with no brakes towing it with a 1960 Ford 1/2 ton pickup after hitting a large dog, totaled the car and hurt the trailer pretty badly puke The dog got up into the front fenderwell and jerk the steering wheel out of my hands and ended up jack knifing the trailer and truck into the other lane, luckily no one got hurt luck
My message is you can't control all things, especially going to the races so be safe and make sure you have more than enough rig to haul the load safely up work
Murphy loves messing with drag racers and hot rodders, correct whistling
