Page 1 of 3 1 2 3
Drag Radials #2484375
04/17/18 09:09 PM
04/17/18 09:09 PM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
I will be purchasing new tires for my wagon. Have narrowed it down to Mickey Pro. Bracket Radial 28- 9.00 - 15. Or the Mickey ET Street Radial 275/60/15.
Does anyone have any experience running these. My car is heavy 4k runs 7.0 in the 1/8th which is what most tracks are around me.
The wagon is a 67 so I'm tire limited. The reason I bring that up is that I have heard the 275 ET street runs big.
Thanks for your help.
Ok
Re: Drag Radials [Re: cudatom] #2484384
04/17/18 09:28 PM
04/17/18 09:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If it is not a street driven deal the pro bracket radial is awesome. I have been very pleased with mine, they are wearing very well and hook great. I do have maybe 100 or so street miles on mine but I try to keep that to a minimum because they aren't cheap.
I had a little trouble with them on a very marginal track but I have learned more about shock settings and will likely be able to tackle that problem next time I run into it.
68 Barracuda Formula S 340
Re: Drag Radials [Re: cudatom] #2484386
04/17/18 09:35 PM
04/17/18 09:35 PM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
^^This^^ If it's not going to be on the street buy the Pro.
Re: Drag Radials [Re: cudatom] #2484388
04/17/18 09:37 PM
04/17/18 09:37 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Hoosier drag radial and PBR are both great. I’ve used both with great results. I too am 4K +.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Drag Radials [Re: cudatom] #2484409
04/17/18 10:46 PM
04/17/18 10:46 PM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
Thanks for the replies. The rims I currently run were drilled for screws as I always ran slicks. Will these holes be a problem when I switch over to radials? Would rather not have to buy a ne set of rims if I don't need to. They are just steels but its still another couple 100 I can use elsewhere.
Ok
Re: Drag Radials [Re: cudatom] #2484420
04/17/18 11:08 PM
04/17/18 11:08 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
For my drag radials, I sanded the inside of the rim smooth and filled the holes with silicone. I also had a oval racer friend cut some additional grooves in the tread for rain when I'm caught in a summer rain and need to get back home. Works well.
Re: Drag Radials [Re: cudatom] #2484423
04/17/18 11:18 PM
04/17/18 11:18 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yeah just fill the holes with silicone, they will be fine.
The Pro's are softer and a bit more sticky than the standard ET.
The big problem with them is that they do not start out with much tread depth from new, if you have a 10 second car go with the Pro but expect to wear either of them out fast on the street.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Drag Radials [Re: ozymaxwedge] #2484451
04/18/18 12:23 AM
04/18/18 12:23 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run the 275 pro's on the street and track. Way too much fun. 18psi everywhere.
'63 Dodge 330
11.19 @ 121 mph
Re: Drag Radials [Re: GY3] #2484456
04/18/18 12:59 AM
04/18/18 12:59 AM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
How true are the 275 size wise. Mickey says 11.4 section width on a 8" rim which will fit. But if its much larger it will be too wide.
That would be the ET Street Pro.
Ok
Re: Drag Radials [Re: cudatom] #2484457
04/18/18 01:00 AM
04/18/18 01:00 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Love the 275 Hoosiers
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Drag Radials [Re: cudatom] #2484458
04/18/18 01:02 AM
04/18/18 01:02 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Tom, if your wagon has stock wheel wells (which I think it does...??), the. 275’s will be hard pressed to fit. The 28x9 PBR’s should fit and would be my choice.
Re: Drag Radials [Re: StealthWedge67] #2484459
04/18/18 01:15 AM
04/18/18 01:15 AM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
Thats exactly what I needed to know, thanks. Yes the wheel wells are stock. So it looks like the PBR's will be my choice. We will see if the side walls hold up better than my Hoosier bias plys. Even at 18 lbs the sidewalls balled up badly. Never spun but always felt I wasn't getting all I should have out of it.
Ok
Re: Drag Radials [Re: cudatom] #2484465
04/18/18 01:26 AM
04/18/18 01:26 AM
Puyallup, WA
Puyallup, WA
I’ll be up for new tires after this year and have been looking mostly at the PBR’s. Please keep us posted on how they work out. Good luck in that big bad wagon this season!
Re: Drag Radials [Re: cudatom] #2484473
04/18/18 01:55 AM
04/18/18 01:55 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I got the 275's in the Barracuda but I had to change the offset/backspace of my steel rims, 5" BS 15x8
1971 Barracuda
Re: Drag Radials [Re: cudatom] #2484535
04/18/18 10:54 AM
04/18/18 10:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Ozymaxwedge,
Tell us about those beadlocks on the steel wheels.
The tires these days are just incredible, lots of good choices.
Thanks,
Bill
Re: Drag Radials [Re: cudatom] #2484880
04/18/18 11:28 PM
04/18/18 11:28 PM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
Ok so I drove to Summit Racing and picked up the 29/9.0 PBR. First impression WOW they are small compared to my Hoosier 28/9.00 bias ply slicks.
I had forgotten my tape so I could not measure rollout there. Got home and one is 86.5 and the other 86.75 so difference is small and will be ok.
What I dont see them doing is growing at least 1.5" when mounted. My bias ply only grew 1" and that was w/20lbs in them to seat the bead.
I need 28" min preferably 28.5 (89.5) which is what I had. What do you guys think? As you know once they are mounted they are mine. The tires are supposed to be 28-28.99 which would be 88- 91" circumference.
Ok
Re: Drag Radials [Re: 340Cuda] #2484904
04/19/18 12:40 AM
04/19/18 12:40 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By 340Cuda
Ozymaxwedge,
Bill
Hey Bill, my Son and I have a little cash on the side bogus business Dream Build Fab making up custom steel wheels, basically give us your old steel rims and we turn them into any size and back space you like.
The rims in the pic are 1969(aussie chrysler) 14" centres, 15x8 outer band that is flipped, close to 5" backspace and a 16" fake beadlock smile The beadlock actually works as the bead is on the 15 plus hard against the 16 lock, tire must be fitted from the back .
https://www.facebook.com/Dream-Build-Fabrication-118542518695958/
1971 Barracuda
Re: Drag Radials [Re: cudatom] #2484928
04/19/18 01:55 AM
04/19/18 01:55 AM
You will be surprised on how much ET and MPH your car will pick up going from the old bias ply tires to the new smaller radials up shruggy
I use to race NHRA stock back a long time ago when the radial slicks first came out for stockers, every one I know that bought them complained about the circumferences until they made the first pass with them on, all of the their cars picked up ET and mph with no other changes boogie scope up
I ran Firestone 9x30 on ten inch wide rims and always ask for the biggest circumference tires they, Parnelli Jones Firestone race tire division in Torance, CA, had in stock. They where all above 95.0 in circumference devil I sold my stocker before the radials came out, I use to help several other Division 7 racers after that and learned form them about the radials being better up
Please let us know your results work grin
Re: Drag Radials [Re: cudatom] #2484972
04/19/18 09:15 AM
04/19/18 09:15 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Do NOT expect a radial to grow at speed. If you need a taller tire to keep the RPM down at the stripe, what you just bought aren't it.
Re: Drag Radials [Re: cudatom] #2484993
04/19/18 10:29 AM
04/19/18 10:29 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I believe the pro bracket is an x5 compound and the Et street radial is R2 compound. Just looked at those 2 at mcCormac racing tire last friday. The pro bracket is much lighter in weight compared to the street radial as well. Gonna get the ET street radial R for my deal.
Page 1 of 3 1 2 3
