AMD windshield 69 B-body
#2484708
04/18/18 05:37 PM
04/18/18 05:37 PM
Posts: 1,383 Az
69hemibeep
Az
Is it just me or are they a pain to install. I remember mine being difficult but I just ripped the upper corner of the $100 gasket. To me it didn't seat low enough.
1969 Hemi Roadrunner 2nd owner
Re: AMD windshield 69 B-body
[Re: 69hemibeep]
#2484716
04/18/18 05:45 PM
04/18/18 05:45 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Is it just me or are they a pain to install. I remember mine being difficult but I just ripped the upper corner of the $100 gasket. To me it didn't seat low enough. Using a soapy/water solution in a spray bottle to aid in install?
[Re: maxi426]
#2484805
04/18/18 09:06 PM
04/18/18 09:06 PM
Posts: 1,383 Az
69hemibeep
Az
Never tried that. I always assumed gravity was my friend and I would be less likely to mess up the sealant on the bottom, but the top corners are a hand full my way.
[Re: maxi426]
#2484851
04/18/18 10:33 PM
04/18/18 10:33 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Put the top edge of the glass in the molding first.I don't know why, but it makes a difference Okay, then you are supposed to pry the gasket into the metal channel with the glass in it? You write that you don't know why it helps but I wonder if the top corners are too sharp of a corner? The last glass I put in was a 65 Barracuda. Old glass, old gasket. I set the gasket in the channel after sealing the entire perimeter, set the glass in the bottom and just worked the plastic knife around each edge until it fit, then pushed in the locking strip. I have a leaky windshield in my 70 Charger and am looking to redo it myself. The gasket and glass were new when the shop installed it. It has a lifetime warranty but I would rather learn it myself. I've installed 3 windshields in A-body cars and got them to seal right.
[Re: maxi426]
#2484893
04/19/18 12:13 AM
04/19/18 12:13 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Put the top edge of the glass in the molding first.I don't know why, but it makes a difference Never heard of that?... I install the bottom first, starting from the bottom center, working to each bottom corner equally, then work from the bottom corners up each side of the A pillar equally each side, then work each upper corner to the top center equally...
[Re: 69hemibeep]
#2485002
04/19/18 10:58 AM
04/19/18 10:58 AM
Posts: 1,383 Az
69hemibeep
Az
Bottom up is how I was taught . The reason I put the brand name up in the title is AMD glass is as thick as OE. Some other after markets had thin glass like I used in my Valiant which goes in easier. Is one gasket better than another?
[Re: 69hemibeep]
#2485078
04/19/18 01:13 PM
04/19/18 01:13 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I start at the bottom also, been doing that way for years. I've had a couple gaskets that were more like soft rubber like the stuff they sell for window run channels... they tear way too easy. It's more like foam than rubber.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2485655
04/20/18 04:14 PM
04/20/18 04:14 PM
Posts: 372 Western NY
maxi426
Western NY
Gasket on the pinch weld, then windshield. Broke one doing bottom first, then looked in the shop manual. Early B-body. Top first seemed odd, but went right in. Worth a try.
[Re: maxi426]
#2485924
04/21/18 03:18 AM
04/21/18 03:18 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I have had two of them installed in different B bodies in the last few years, one guy had to start at the top corner and work it in from there, The other car had an NOS MOPAR gasket and it went in OK bottom first. He used foamy glass cleaner as the lube...
[Re: 69hemibeep]
#2486040
04/21/18 01:05 PM
04/21/18 01:05 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
I just finished installing the windshield in my '64 B body Polara and the Dodge manual for that car stated to install the top of the windshield in the gasket first. The gasket goes on the pinch weld first, not on the glass. Then the glass is inserted into the gasket on the top and the gasket is then worked onto the glass down both sides and across the bottom. You can't do it the conventional way with cord or twine pulling the gasket in place. You have to use a plastic tool or a thin smooth piece of wood to work the gasket in place. Its a pain but can be done by one person if you take your time. Had my wife help me set the glass in place and I did the rest by myself. The total installation took about 3 hours including the locking strip. The gasket I used had an integral locking flange and didn't use the separate strip. Was much easier. I will say that this installation reminded me of my sister-in-law. It was a real b-it-ch compared to the rear window, which went in the conventional way and took a total of 20 minutes to do. Here's the locking flange.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: 69hemibeep]
#2486043
04/21/18 01:16 PM
04/21/18 01:16 PM
Posts: 1,383 Az
69hemibeep
Az
I just read my service manual and it does say top first so Sunday I'll give it a try. Thanks for the input
[Re: 69hemibeep]
#2486452
04/22/18 04:38 PM
04/22/18 04:38 PM
Posts: 1,383 Az
69hemibeep
Az
Its official, its easier to do the top first but it takes two until you get some of the bottom gasket pulled up to support the weight.
[Re: 69hemibeep]
#2486623
04/22/18 11:56 PM
04/22/18 11:56 PM
Posts: 18,417 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I just read my service manual and it does say top first so Sunday I'll give it a try. Thanks for the input.-----Its official, its easier to do the top first but it takes two until you get some of the bottom gasket pulled up to support the weight. You are right as the manual says to do it that way. I always did the opposite only because I never thought that it was necessary to look to the manual and I just did what I saw the professional glass installers do. I think a couple of suction cups would help. I will be installing mine in the near future and will try it top side in first and see how it goes.
[Re: 69hemibeep]
#2486743
04/23/18 10:36 AM
04/23/18 10:36 AM
Posts: 1,383 Az
69hemibeep
Az
Once we got the top and part of the sides in it made life easier to push the bottom of the gasket out from the inside as your helper runs the stick from the outside edge.
