Megablock Q’s #2483516
04/16/18 11:03 AM
04/16/18 11:03 AM
Wallkill, NY
Scamp9572 Offline OP
Wallkill, NY
I have a Cummins era Siamese block in the rebuild stage. I’ve done some research but finding limited info. Is there a main stud kit available from anyone? I found one for a world block, not sure if it would interchange. Is there an off the shelf 4.5 bore ring set ? Found stuff listed for Chevy stuff. A bore is a bore ?? Need 1/8 1/8 1/16. Builder prefers Totalseal.
Re: Megablock Q’s [Re: Scamp9572] #2483534
04/16/18 11:47 AM
04/16/18 11:47 AM
gregsdart Offline
gregsdart  Offline
Rings, no problem. Call ARP and ask, or search Jegs or Summit on the stud kit.
Re: Megablock Q’s [Re: Scamp9572] #2483676
04/16/18 04:22 PM
04/16/18 04:22 PM
Wallkill, NY
Wallkill, NY
Called ARP. Nothing in the catalog. Have to measure everything and see if they can match it up. Nothing in the milodon catalog online. Time to measure I guess. Thank you.
Re: Megablock Q’s [Re: Scamp9572] #2483701
04/16/18 04:46 PM
04/16/18 04:46 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
ARP 145-5602 is what you need.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Megablock Q’s [Re: Hemi_Joel] #2483721
04/16/18 05:11 PM
04/16/18 05:11 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, this is the kit I used on my Megablock Hemi. However, my main side studs were just a little too short for comfort. Hardly had any thread engagement in order to install the 12 point nuts. Not sure if it was a packaging error but I ordered some that were slightly longer in length. ARP sent them at no charge.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Megablock Q’s [Re: Scamp9572] #2483797
04/16/18 07:47 PM
04/16/18 07:47 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
We stock the 145 5602s
Todd
Re: Megablock Q’s [Re: Scamp9572] #2483951
04/16/18 11:34 PM
04/16/18 11:34 PM
Wallkill, NY
Wallkill, NY
That looks like the ticket! Mine is a wedge, but the block is essentially the same right? Thank you.
