Sill plates #2483591
04/16/18 01:58 PM
04/16/18 01:58 PM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
Did all the 70 Challengers come with sill plates?
1970 challenger convertible
Re: Sill plates [Re: mikeporp] #2483592
04/16/18 02:00 PM
04/16/18 02:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Sill plates - Yes.
Sill moldings - No.
Re: Sill plates [Re: mikeporp] #2483664
04/16/18 04:08 PM
04/16/18 04:08 PM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
What is the difference? I'm talking about the approximately 4" wide scuff plates.
Re: Sill plates [Re: mikeporp] #2483800
04/16/18 07:49 PM
04/16/18 07:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sill plates are located in the door jamb, 70-74 Cuda and Challenger are the same piece
Sill moldings, also called rocker moldings are obviously located on the rocker panel, these are you exterior decorative moldings
and for sh1ts and giggles, belt moldings are the moldings located on the top edge of the exterior portion of the door top and rear qtr top edge in front of the rear qtr window, the Challenger 70-1 has additional belt moldings that attach to the upper rear edge of the fender top and the rear edge of the hood, where as the Cuda only has the door/qtr belt moldings
Mike
Re: Sill plates [Re: mikeporp] #2484524
04/18/18 10:35 AM
04/18/18 10:35 AM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
Thanks for the info. So if my car originally came with the rocker panel moldings there would be holes for the screws.
