Re: 413 industrial block
[Re: Tommy D]
#2484232
04/17/18 02:44 PM
04/17/18 02:44 PM
Posts: 8,373 fredericksburg,va
cudaman1969
fredericksburg,va
Thank you for clearing that up. Guess our's is a 426. Do you know if the block is thicker on the 426 than the 413? Pretty sure our engine builder told us it's .060 over. Can't find our receipt with the specs after Dad moved. The block I got was a 426--4-1/4 bore, I had it bored 60 over, rite out of the crane. I traded a 3-3/4 crank for it, seems he had picked up an early industrial 413 with the extended crank and needed the later style crank to mate back up to ?? Never asked if the engine ran the truck or the crane.
[Re: Porter67]
#2484406
04/17/18 10:39 PM
04/17/18 10:39 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Being in the business for almost 40 years, big block cores (cases) are getting hard to find, at least out here, SoCal.
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: SCATPACK 1]
#2485011
04/19/18 11:18 AM
04/19/18 11:18 AM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
IF you don't care, post up some pictures of the spark plugs and combustion chamber. I am intrigued by that design. Never ever saw it before. And I thought I had worked on every Mopar block ever made. Here's a couple of pics for you. First to show you how the spark plugs are positioned and the 2nd to show how much taller these heads are than standard BB heads. The intake manifold is supposed to work on normal heads, but I have not verified this. I'm planning on stripping it to the shortblock this weekend, get some more pics, and post for yall on Monday.
[Re: an8sec70cuda]
#2485204
04/19/18 06:11 PM
04/19/18 06:11 PM
dogdays
IF you check the casting number lists, there is ONE casting number that was used for 413 AND 426 industrial engines. There are, I believe, other industrial 413 casting numbers and industrial 426 casting numbers. AS WITH ANY MOPAR CASTING, let the sonic checker tell you the answer. That "underbored 440" crap is just that, crap.
The problem with 413s is that they should be free engines, the same as 318s and 361s. But give a novice a "bigblock Mopar" engine and he'll think it's gold. Those motorhome 413s show up on Craigslist for $800, makes me puke. Now if they were priced right, they might be interesting. But a 360 with a 4" crank and decent heads will outrun one in the same car.
R.
[Re: dogdays]
#2486769
04/23/18 12:26 PM
04/23/18 12:26 PM
an8sec70cuda
A few more pics...got the heads off. Trying to get it unstuck. Valve sizes are real small...1.88 intake, 1.50 exhaust.
The intake manifold from this 413 motor WILL work on any other RB w/ the typical cylinder heads. I bolted it on a 440 I have on another stand and it fit right up.
[Re: an8sec70cuda]
#2486770
04/23/18 12:27 PM
04/23/18 12:27 PM
an8sec70cuda
Dished pistons and extra ribs on the side of the block.
[Re: an8sec70cuda]
#2904280
03/30/21 01:25 PM
03/30/21 01:25 PM
an8sec70cuda
Digging this old thread back up for a quick update. I bought a sonic checker and checked the walls on this 413 block. Like Cab, dogdays, and others have said...you can't bore this thing to 440 bore size. There's enough meat to go .060" or .070" oversize, but no more than that.
[Re: EchoSixMike]
#2904471
03/31/21 06:51 AM
03/31/21 06:51 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Good timing, Top fuel Mike is getting some 413 pistons made ( hopefully) with some decent compression. But it’s still a truck motor and just like the 383 a small bore cousin of a better option (400)... ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif) Oh yeah, mine 413 is going in a 64 D200, which is a ‘truck’ cos I can’t find a 426 boohoo... ![violin violin](/ubbthreads/images/graemlins/custom/violin.gif) I was gonna use the ‘truck’ heads but they is so flipping heavy it’s scary... ![XmasTruck XmasTruck](/ubbthreads/images/graemlins/custom/XMasTruck.gif)
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: an8sec70cuda]
#2904484
03/31/21 08:59 AM
03/31/21 08:59 AM
Posts: 12,326 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have a couple of those engines laying around in the barn from motor homes. Complete from carb to pan including accessories. One still has the tranny attached. Just use them for nuts and bolts for other projects.
Master, again and still
[Re: DaveRS23]
#2904485
03/31/21 09:06 AM
03/31/21 09:06 AM
an8sec70cuda
I figure I'll hold onto it mainly b/c it has a good forged crank and a set of LY rods. It's wrapped up and sitting in a corner under some shelves next to a bunch of 440s. I got rid of all my low deck stuff, so this one fits right in, lol. It is nice to have some extra complete core motors for random parts every now and then.
[Re: an8sec70cuda]
#2904487
03/31/21 09:11 AM
03/31/21 09:11 AM
Gtxxjon
Isle of Sheeps
If I remember correctly the crank is the older design from the fifties?
About 1/2” longer and Eight bolts? Great for a custom build but no good for a stock trans.
[Re: Gtxxjon]
#2904489
03/31/21 09:13 AM
03/31/21 09:13 AM
an8sec70cuda
About 1/2” longer and Eight bolts? Great for a custom build but no good for a stock trans. I'm sure some have that type of crank, but this one doesn't. It's a standard 6 bolt crank w/ the typical flange.
[Re: an8sec70cuda]
#2904509
03/31/21 09:51 AM
03/31/21 09:51 AM
Gtxxjon
Isle of Sheeps
Nice one 8secs!
I had an 8secs Street Dart back in the 90's too. (in Avatar) Koffel 547ci engine with a bruno lenco ran 8.30 @ 180 best ever!
I still dream of those 'Days of Glory past' lol...
[Re: mgoblue9798]
#2913780
04/23/21 09:05 AM
04/23/21 09:05 AM
an8sec70cuda
If you are not going to use those heads, I could use the set of push rods and head bolts for a frankenstein 440 with 413 heads I am building. They are too long to work with regular heads. I would have gladly given them to you, but they went to the scrap yard 2 years ago shortly after I started this thread.
