Re: 440 Engine Block best production years! #2483208
04/15/18 06:40 PM
04/15/18 06:40 PM
Ontario. Canada
SunnyMopar Offline OP
Ontario. Canada
Hi... I am new Mopar member.. Need help!!
Have a 70 Cuda, and in the process of putting a 440 -6pack!
Found one for sale, Stock rebuilt... with a 6-pack set up ,
Its Carbs to oil pan complete, and heard running!
I am concerned about the YEAR of this engine???
Its is a 1973 Block!
I am not hat knowledgeble on engine 440-blocks..
And which are better year production??
Hope some one has experience and knowledge..
for the big Mopar Blocks to help me!
Thank you so much, Sonny
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483209
04/15/18 06:43 PM
04/15/18 06:43 PM
Sonny welcome aboard. (fasten your seat belt!). See if Andys 440 manifesto is in the archives. EDIT I looked & saw the 451 manifesto which ain't it but someone will point you to it plus offer more info on your Q.
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483210
04/15/18 06:48 PM
04/15/18 06:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483241
04/15/18 07:48 PM
04/15/18 07:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
'76 has the thicker main webs.
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483244
04/15/18 08:00 PM
04/15/18 08:00 PM
Mopar used the same casting numbers on the 440 blocks from 1966 to late 1971 blocks. Starting in early 1972 they changed the casting numbers on the 440 passenger car motors only, HD, industrial and marine motors weren't changed shruggy
The main thing you need to know about is if that motor is internally balanced or externally balanced scope If the seller doesn't know see if the crankshaft balancer has a oblong external ring around it or not, if it does it means it is externally balanced and that balancer should say for 440 motors cast into it scope
If it doesn't have a balancer like that and does NOT shake when running up through 5000 RPM then it is probably internally balanced, up The bad thing about externally balanced Mopar V8 is Mopar used external weights on both ends of the crankshaft on the flywheel or converter with weights welded onto the converters whiney
Please let us know what you find out work
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483266
04/15/18 08:40 PM
04/15/18 08:40 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
There are no real 'bad production years' when it comes to B/RB engine blocks.
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483293
04/15/18 09:22 PM
04/15/18 09:22 PM
AndyF Online content
AndyF  Online Content
Nothing wrong with a 1973 block but that isn't a stock engine which means someone rounded up bits and pieces and built an engine. Whether or not they did a good job is the question. My fear is that it is a low performance cast crank short block with low compression pistons that someone added a six pack intake to. If that is the case then it isn't worth very much money. Buyer beware and all of that.......
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483326
04/15/18 10:11 PM
04/15/18 10:11 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Welcome to Moparts!!
11B40
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483370
04/15/18 11:48 PM
04/15/18 11:48 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Keep in mind the later blocks do have a very large bevel on each cylinder.
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483415
04/16/18 01:13 AM
04/16/18 01:13 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
If it’s priced right snag it. Check to your comfort level.
Unfortunately when you go to sell that car people will get all twisted up, contorted, and maybe have seizures when they find out you put a bad year, off year, or whatever they call it block in it. Because that matters a lot. Just talk to joe average. He’ll tell you. Can’t do that. Not allowed. Against rules. Nope.
“Know what ya shoulda done...”
I want my fair share
Re: 440 Engine Block best production years! [Re: Cab_Burge] #2483439
04/16/18 02:19 AM
04/16/18 02:19 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Edit Cab
Should say "CAST CRANK ONLY"
1963 Plymouth Max Wedge
1971 Barracuda
Re: 440 Engine Block best production years! [Re: ozymaxwedge] #2483446
04/16/18 02:51 AM
04/16/18 02:51 AM
Edit Cab
Not always, the 1970/71 forged steel crankshaft HP motors with the big heavy six pack rods didn't have that written, cast, on them with that external cast in weight shruggy
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483529
04/16/18 11:39 AM
04/16/18 11:39 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Can a pistons proximity to zero deck be determined without pulling off a head and measuring? The thought of a Six Pack on top of smogger dogger type pistons makes me sad.
Keep old mopars alive.
Re: 440 Engine Block best production years! [Re: 2boltmain] #2483557
04/16/18 12:55 PM
04/16/18 12:55 PM
moparx Offline
moparx  Offline
welcome to the board sonny ! wave now you know where to spend all your "free" time. biggrin
beer
Re: 440 Engine Block best production years! [Re: 2boltmain] #2483558
04/16/18 12:56 PM
04/16/18 12:56 PM
moparx Offline
moparx  Offline
beer
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483568
04/16/18 01:09 PM
04/16/18 01:09 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
A bore scope can help you determine the pistons, dished or flat tops, there might even be a part number on top of pistons that can be seen. I think it would be worth a try.
Have a great day
Iowan
"obsolete is neat"
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483628
04/16/18 03:06 PM
04/16/18 03:06 PM
Chicago
PurpleBeeper Offline
Chicago
In my opinion, all years 440 blocks are just fine unless you have a blower, 3-stages of nitrous, etc. with more than maybe 600-650 horsepower. Also, 74+ blocks use a larger lip on the center main bearing which is preferred, but not required.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483795
04/16/18 07:34 PM
04/16/18 07:34 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why ... a "six pack" is just a 2 bbl motor until the vacuum kicks in the outboard carbs. And unless you plan to race the thing , who cares if its down on power a bit.
Re: 440 Engine Block best production years! [Re: Stanton] #2483868
04/16/18 09:44 PM
04/16/18 09:44 PM
IN
ahy Offline
ahy  Offline
IN
In terms of years of block for B/RB, agree they all can be good. Cylinder wall thickness, verified by sonic check, is a big variable for any block regardless of year manufactured. Also other details about block condition which a good machinist and engine assembler checks.
If you do not know this detail (with confidence) about the engine you are considering buying, buyer beware.
I run a '78 "smogger" block pretty hard and no issues (592 HP/687 ft lb). It checks out OK in wall thickness and other areas. Also the late 400's
had stronger main bearing support vs earlier blocks and in this respect were better.
Re: 440 Engine Block best production years! [Re: SunnyMopar] #2483982
04/17/18 12:38 AM
04/17/18 12:38 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The ones with the distributor in the front are best.
Kevin
