Taller big block oil pump? #2483321
04/15/18 10:05 PM
04/15/18 10:05 PM
gregsdart Offline OP
After restricting pushrods, I am still a little short on hi rpm oil flow, and am looking for a better rotor and body than a melling hemi hi volume. What works? I do have a steering shaft very close, so a minimal size increase is somewhat important.
Re: Taller big block oil pump? [Re: gregsdart] #2483330
04/15/18 10:16 PM
04/15/18 10:16 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Alc/fuel(RCD pictured)pump will push more oil than a Melling or eqivilant HV pump
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Taller big block oil pump? [Re: gregsdart] #2483343
04/15/18 10:35 PM
04/15/18 10:35 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Still a lack of sufficient pressure?
Doug
Re: Taller big block oil pump? [Re: gregsdart] #2483351
04/15/18 10:53 PM
04/15/18 10:53 PM
Last pass i saw 55 on the gauge, running 10 inch vacuum, so i am on the edge,trap rpm 7500.
Re: Taller big block oil pump? [Re: gregsdart] #2483352
04/15/18 10:56 PM
04/15/18 10:56 PM
I spotted a Milodon segment (gears and outer housing) # 21815 that has a built in second entry, to allow dual line pickup without having to be taller, and i think it will work with my current cover. Anybody use it?
Re: Taller big block oil pump? [Re: gregsdart] #2483377
04/16/18 12:00 AM
04/16/18 12:00 AM
AndyF Offline
AndyF  Offline
Are you sure it is a volume issue? Maybe you just need to shim up the pressure spring?
Re: Taller big block oil pump? [Re: gregsdart] #2483394
04/16/18 12:25 AM
04/16/18 12:25 AM
It will hold 70+ psi cold, Andy.
Re: Taller big block oil pump? [Re: gregsdart] #2483417
04/16/18 01:17 AM
04/16/18 01:17 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I would still try shimming it. That has worked for me even when logic says it shouldn't. And it's a cheap easy test.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Taller big block oil pump? [Re: Hemi_Joel] #2483443
04/16/18 02:41 AM
04/16/18 02:41 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
We have used the Milodon 21815 for years but you better hurry if you want one. Milodon is canceling them and bringing out a new billet version.
TOdd
Re: Taller big block oil pump? [Re: gregsdart] #2483444
04/16/18 02:42 AM
04/16/18 02:42 AM
AndyF Offline
AndyF  Offline
Try shimming it to see what happens. A HV pump can flow enough oil to overcome a soft spring and force open the bypass. Like Joel says, it is an easy test. Just takes a few minutes to drop a washer or two in behind the spring and see what happens.
Re: Taller big block oil pump? [Re: gregsdart] #2483468
04/16/18 07:17 AM
04/16/18 07:17 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Mine has the .100"? taller stock style rotors, Indy cover with a single line, and the black spring. Push rod oil with .050ish restrictors (3/32"roll pins). Rods were .003, mains .004, lifter bushings close to .002. The spring has been trimmed 2 full coils. There is no static tension on it. Runs 70psi@7200.
Doug
Re: Taller big block oil pump? [Re: gregsdart] #2483480
04/16/18 09:02 AM
04/16/18 09:02 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've had good luck with the 21815 pump for years, but I don't know how tall it is compared to a Melling pump height. Always great hot idle pressure and trap pressure. Usually, if anything, it has to be turned down from stock setup. I know that the Milodon covers are massive, due to all of the plumbing going through it.
[image][/image]
Re: Taller big block oil pump? [Re: AndyF] #2483485
04/16/18 09:09 AM
04/16/18 09:09 AM
Thanks, will do. Maybe the volume of oil needed at speed creates more pressure between rotors and the bypass just trying to keep up? another thought is pressure drops as flow in a pipe increases, so the pressure at the back of the motor where the gauge is connected?
I saw that at work. Printing ink(thick!) Wouldn't flow through a four inch pipe 150 feet even though the pressure at the pump was maybe 100 psi! Some bean counter was going to save the company money. " we don't need that 6 inch pipe!"
We had to go to portable canisters!
Re: Taller big block oil pump? [Re: gregsdart] #2483611
04/16/18 02:22 PM
04/16/18 02:22 PM
I've used a bunch of those older Milidon pumps listed, I like them up
Re: Taller big block oil pump? [Re: gregsdart] #2483616
04/16/18 02:42 PM
04/16/18 02:42 PM
That pump is 1.950 long from the block mounting surface to the inside of the pump cover up
Re: Taller big block oil pump? [Re: gregsdart] #2483971
04/17/18 12:16 AM
04/17/18 12:16 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
That's a great pump but if you are using the dual line system now with the spacer you will have to buy a midlength oil drive. Milodon 21523 if you are using a bronze gear.
The KB pump has 1-1/2 rotors but it uses external filter.
I have had one of the aluminum Milodon pumps bind up on me when installed. Can't remember if it was that one or the billlet one. When you are torquing on the oil pump have somebody turning the oil pump with the primer tool and make sure it doesn't start binding on you as you torque it down.
2011 Drag Pak Challenger
Re: Taller big block oil pump? [Re: gregsdart] #2484595
04/18/18 12:52 PM
04/18/18 12:52 PM
Thanks to all that answered, I have lots of ways to skin this cat. From just a washer under the bypass spring, which I figure will help, since you guys say so, to adding the five lobe Milodon pump segment, to going dual line since the 21815 unit will allow it with my tight clearances. I went ahead and ordered the 21815,to get all those options. I am going to use the 21815 and run the single line to it, since it makes a straight on entrance to the lobes, not the 90 degrees of a stock type pump. Also I will start with at least 75 psi cold, unless you guys think I should shoot for 80 cold.
Re: Taller big block oil pump? [Re: gregsdart] #2484684
04/18/18 04:18 PM
04/18/18 04:18 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Milodon 21815 here 70 psi cold, 30-40 hot idle and 100-110 WFO. I shimmed the crap out of the stock spring.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Taller big block oil pump? [Re: gregsdart] #2484854
04/18/18 10:37 PM
04/18/18 10:37 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
One thing to keep in mind that no one has mentioned, that Milodon pump is very efficient. I don't know how much capacity that you have, just make sure that you don't suck the pan dry. Seen it happen with one of those.
Brian
Re: Taller big block oil pump? [Re: gregsdart] #2484922
04/19/18 01:32 AM
04/19/18 01:32 AM
Thanks Brian. I run a total of 12 or 13 qts, with an acusump for protection, but i plan to hook my data logger to the oil galley to see how things are.
