Re: Help I.D. Steel Wheel
[Re: ro23_j]
#2483388
04/16/18 12:16 AM
04/16/18 12:16 AM
Posts: 8,399 Highland, MI.
Sunroofcuda
Highland, MI.
It's a 1968-9 style wheel. Kelsey-Hayes, plant 2, looks like November 20, 1968 build date. Could have gone on a C-body, or a B-body. This wheel would have covered many different models - maybe even pickup trucks. Not a valuable wheel.
[Re: 64Post]
#2484437
04/17/18 11:51 PM
04/17/18 11:51 PM
Posts: 3,089 Michigan
A727Tflite
Should be $100/set at the junkyard if you're not concerned about running the correct dog dish caps.
Several choices available if you want to run the correct caps. Thanks for the reply. I have a correct set of 14's with the large pattern for the correct dog dishes but I think the car would look puny without 15's. I have a remedy for the small center to use the large dog dish so going to chase that down first.
[Re: A727Tflite]
#2484551
04/18/18 11:15 AM
04/18/18 11:15 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I have a correct set of 14's with the large pattern for the correct dog dishes but I think the car would look puny without 15's. Not to mention the availability of 14" tires is practically nonexistent.
I have mechanical Aptitude. I can screw up anything.
[Re: ro23_j]
#2484682
04/18/18 04:12 PM
04/18/18 04:12 PM
Sunroofcuda
Highland, MI.
I now have access to a supply of 15x5" wide pre-68 wheels. Just got a set in. These will accept the larger diameter 67 & earlier dog dish caps. They can be widened, but I do not do any wheel mods. I have not had a pre-68 Mopar wheel in over 3 years. Only other ones I used to get in 15" were 5.5" wide.
[Re: Sunroofcuda]
#2484856
04/18/18 10:41 PM
04/18/18 10:41 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I'm getting ready to sell off 2-15 X 5, 2-15 X 5.5 and 2 widened 15 X 8. All of them are/were K wheels.
Now that the large cap centers are available for the 15" rim shells the K wheels just aren't the only option anymore. They still bring good money though.
