Factory console tachometers #2483182
04/15/18 05:39 PM
04/15/18 05:39 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Does anyone reproduce Factory console tachometers for 66, 67 b-body consoles? Housing and electronics included.
Re: Factory console tachometers [Re: RBSat66] #2483297
04/15/18 09:28 PM
04/15/18 09:28 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Not that I'm aware of. The circuit board is available. Keep in mind that the internals of the '66 tach is very different from the '67. If you find a used tach and it's from a '66, make sure you get the sending unit. The tach was also used in Darts all the way until 1969, so widen your search a little.
Re: Factory console tachometers [Re: Jim_Lusk] #2483355
04/15/18 11:00 PM
04/15/18 11:00 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I believe 68 and 69 tach had differences as well.. in the wiring
Re: Factory console tachometers [Re: mccannix] #2483407
04/16/18 12:57 AM
04/16/18 12:57 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The console wiring was different as the backup light switch moved to the transmission in 1969, but I believe the tach, itself, was the same.
