Re: Deck height - crank centerline
[Re: BCFKody]
#2483025
04/15/18 12:52 PM
04/15/18 12:52 PM
RapidRobert
a piece of round steel stock cuz with the mike being flat & the bore being round the mike will not sit down flat on the rounded surface.
[Re: BCFKody]
#2483042
04/15/18 01:07 PM
04/15/18 01:07 PM
Posts: 3,395 Pa
Hot 340
Pa
I get the math. (Measurement + 1/2 the main bore dimension = deck height). But I don’t understand what you mean by a “small pin.” Also, are 10-11 in. Micrometers available? Or are you using something else? pin size can be arbitrary..1/4 would work..see pic above
[Re: Hot 340]
#2483048
04/15/18 01:20 PM
04/15/18 01:20 PM
RapidRobert
You could use a round pin & a tape (dont use the slotted chrome hook on the end) & several helpers which will get you "close" & purchasing that big of mike will be expensive unless you plan alot of use to get your moneys' worth. what I would suggest is putting the block belly up in the back of your pickup & driving to the machine shop & have/pay them to come out & take a measurement which would take several minutes & for sure call ahead & schedule a time (& hopefully you have a shop close by).
[Re: DusterKid]
#2483058
04/15/18 01:39 PM
04/15/18 01:39 PM
Posts: 3,504 DFW
mr_340
DFW
I used a 12" Mitutoyo caliper similar to the method of Hot 340 except no pin.
Floyd Lippencott IV
[Re: mr_340]
#2483083
04/15/18 02:27 PM
04/15/18 02:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I used a 12" Mitutoyo caliper similar to the method of Hot 340 except no pin. I did my last block just like this.. worked great
[Re: DusterKid]
#2483130
04/15/18 04:17 PM
04/15/18 04:17 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
I usually use a 12" caliper as well, but they are not as precise as a micrometer. When using a micrometer, you can get a .2500 ball with a rubber holder for the anvil of the micrometer. That makes it easy and accurate.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: DusterKid]
#2483136
04/15/18 04:22 PM
04/15/18 04:22 PM
Hemi_Joel
Minnesota
Here's a micrometer for you. Then you can do it yourself for many years. mike
[Re: DusterKid]
#2483200
04/15/18 06:20 PM
04/15/18 06:20 PM
Posts: 4,206 New York
polyspheric
New York
Remember that the main bearing bore (as shown) is not the journal size, and not listed frequently. Some bearing catalogs list the actual bearing OD, but that may not include crush. Doing the same measurement using the actual journal in place removes this variable, instead subtract 1/2 of the measured journal OD (duh).
Boffin Emeritus
[Re: A727Tflite]
#2483236
04/15/18 07:43 PM
04/15/18 07:43 PM
Posts: 1,772 Keymar, MD
DusterKid
Keymar, MD
Is there a reason you can't throw a crank and piston/rod assembly in a bore and check it that way? Pretty much every aftermarket set of pistons has a CD within a .001" and a set of rods made by a good company have about the same C to C distance. Throw the same piston/rod in each corner and you know if the decks are parallel while you are at it.
No special tools, and more accurate than a tape measure and straight edge. I have a std block and want to bore it .030 over. I'm thinking of going stroker and looking at pistons from dish to flat tops. Some are 2.05 to 2.067 compression height. I'd like to know my deck height so I can figure out which pistons will do what I want to be able to do. I'd like to start out around 10.1 compression but have the option to increase it with a thinner head gasket if/when I want to go faster. Can't stick a .030 over piston in a std bore block.
[Re: DusterKid]
#2483292
04/15/18 09:21 PM
04/15/18 09:21 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
Every original stock Mopar V8 block I've taken apart and had blueprinted was way off on the stock deck heights, a lot taller than the NHRA specs. call for I've seen them tapered from front to back also My main message is count on having your block deck cut to get it close to stock blueprint heights
[Re: polyspheric]
#2483299
04/15/18 09:29 PM
04/15/18 09:29 PM
dartman366
Mt. Vernon, Ohio
Remember that the main bearing bore (as shown) is not the journal size, and not listed frequently. Some bearing catalogs list the actual bearing OD, but that may not include crush. Doing the same measurement using the actual journal in place removes this variable, instead subtract 1/2 of the measured journal OD (duh). or mic the bearing bore of the block and add 1/2 of your dimention.
[Re: DusterKid]
#2483347
04/15/18 10:45 PM
04/15/18 10:45 PM
polyspheric
New York
True, that. Almost every data point is looser than called out.
Boffin Emeritus
