Quick Fuel 4150 question #2482274
04/13/18 07:24 PM
04/13/18 07:24 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
Does any Holley 4150 dual feed fuel line fit these? I have the BDQ 850 Quick Fuel carb and don't see anything for it specifically, however I am not wanting to order a fuel line just to return it.
eBay-cdwmotorsports
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482278
04/13/18 07:31 PM
04/13/18 07:31 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I'm not sure what the adapters that come with the QFT bowls are, but like older holley bowls, you can screw a 7/8-20 line or fitting into the QFT bowls.
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482280
04/13/18 07:34 PM
04/13/18 07:34 PM
Martinsville, IN
Martinsville, IN
Thats what I thought, I figured 4150 was 4150. The line set I'm looking at is 8AN to 7/8x20
eBay-cdwmotorsports
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482305
04/13/18 08:35 PM
04/13/18 08:35 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
You could always call quickfuel and ask them
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482347
04/13/18 10:41 PM
04/13/18 10:41 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Go find a Holley fuel bowl fitting and try it. I must have a dozen of them floating around in my garage. Someone in town must have one.
[image][/image]
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482355
04/13/18 11:06 PM
04/13/18 11:06 PM
Martinsville, IN
Martinsville, IN
I know the bowl fittings are 7/8x20 I was wondering about the width
eBay-cdwmotorsports
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482550
04/14/18 01:09 PM
04/14/18 01:09 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
run a flexible one like this, get a name brand one if that's your thing...
be sure and pull the allen screw out of the port for the gauge hookup and put some thread sealant on it.
ebay fuel line
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482617
04/14/18 03:21 PM
04/14/18 03:21 PM
Why #8 AN? 6AN line I.D.(.375) is way bigger than any needle and seat size I've seen or heard of shruggy work
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2482745
04/14/18 09:46 PM
04/14/18 09:46 PM
Martinsville, IN
Martinsville, IN
Cause that's what I used. No real reason why, all of my line is 8AN except the 10AN feeding the pump
eBay-cdwmotorsports
Re: Quick Fuel 4150 question [Re: cdwmotorsports] #2483156
04/15/18 05:01 PM
04/15/18 05:01 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
It can & does vary depending upon the type of fuel bowls being used.
The early (standard) Holley bowls and the common less expensive aluminum bowls used on some QF and others' carbs are the same distance between fuel fittings. The later Holley Ultra H/XP aluminum and QF's "Fuel Chute" bowls are spread farther apart between fitting due to increasing their fuel volumes.
The Holley Ultra H/XP and QF "Fuel Chute" bowls don't use the traditional 7/8 x 20 fittings, either, IIRC.
