Help on foam seals #2481922
04/13/18 12:04 AM
04/13/18 12:04 AM
kansas
70B5Vert Offline OP
70B5Vert  Offline OP
kansas
I found an old box with some original package Mopar parts.
here are the numbers and description printed on them.
3696572 seal
3696573 seal
3696136 seal
3582994 seal
3582995 filler
these all appear to be black foam about 1/4 in thick and likely to have 1 side sticky.
I tried google...no luck.
also a box with a wire harness that is appears to be under dash.
under dash. mopar box says Wiring 2483347.
any help will be appreciated!!
Deron
17 Charger Daytona
70 'Cuda 340 My 1st car
70 'Cuda 340 Vert
73 Duster 318
73 Cuda 440 Drag
1.405 60ft
10.243 et 130.54 mph
6172 Diecast Mopars
http://www.facebook.com/profile.php?id=100001409817007&sk=photos
Re: Help on foam seals [Re: 70B5Vert] #2482079
04/13/18 11:43 AM
04/13/18 11:43 AM
regarding the seals, can you post a pic?
Re: Help on foam seals [Re: 70B5Vert] #2482091
04/13/18 12:05 PM
04/13/18 12:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not in my 73 74 passenger car books. They have numbers real close to those and they are front door glass seals of some type. Maybe truck parts?
