Carb with in tank pump #2481489
04/12/18 09:00 AM
04/12/18 09:00 AM
nj
JAMESDART Offline OP
nj
I'm running a tanks inc setup in my duster with the ez efi I like the tank. Thinking of running one on my dart with the 451. I wanted to keep a mexxanical pump but They seem to be a hassle anymore with this new gas.
Re: Carb with in tank pump [Re: JAMESDART] #2481509
04/12/18 10:28 AM
04/12/18 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
So.. whats your question.. I built my tank but
I am using a external mounted pump( I changed
over to Holley HP injection after I built the
tank so I kept the pump external
wave
Re: Carb with in tank pump [Re: JAMESDART] #2481524
04/12/18 11:04 AM
04/12/18 11:04 AM
nj
nj
Is anyone here using an in tank pump with a carb. I'm looking at tanks inc with the walbro in tank pump, normally for efi. I like that tank setup.
Re: Carb with in tank pump [Re: JAMESDART] #2481533
04/12/18 11:17 AM
04/12/18 11:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
As long as you use a return style regulator I don't see a problem with it.
68 Barracuda Formula S 340
Re: Carb with in tank pump [Re: JAMESDART] #2481544
04/12/18 11:36 AM
04/12/18 11:36 AM
Wisconsin
Jet Doc Offline
Jet Doc  Offline
Wisconsin
I'm running a Aeromotive 15 gal tank with the built in A1000 pump, works great, quiet and super clean install. It's not cheap though and you do need to run a return style regulator.
