Re: cam/brain help
[Re: B1MAXX]
#2481534
04/12/18 11:20 AM
04/12/18 11:20 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The MP620 cam actually measures out at about 283@.050, not 275. You didn't specify what rocker ratio you'll be running. With 1.5's I'd use #5.
Some SR's I tweaked recently:
Lift------int .100---72.5 .200--153.6 .300--213.6 .400--270.0 .500--314.1 .600--338.4 .700--354.1 .800--357.1
Re: cam/brain help
[Re: B1MAXX]
#2482024
04/13/18 09:50 AM
04/13/18 09:50 AM
Posts: 4,045 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
...Wheres a good place to start looking at the back-up on the flow? The short-side radius.
Re: cam/brain help
[Re: HardcoreB]
#2482095
04/13/18 12:14 PM
04/13/18 12:14 PM
fast68plymouth
So. Burlington, Vt.
...Wheres a good place to start looking at the back-up on the flow? The short-side radius. But...... Do the valve job first. SR's are pretty finicky about the transition from the bowl to the seat. This isn't where your problem is with the flow dropping off at high lifts(that's almost certainly the short turn), but it can have a noticable impact on the final results.
