Air conditioning compressor ideas #2479066
04/07/18 09:39 PM
04/07/18 09:39 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
In my future there is possibly a triple black '70 Road Runner, 383 pistol-grip 4speed with a/c. The car has a 440 in it now. I was thinking of putting my six pack set up on it along with a complete air grabber hood assembly. As we all know, the factory RV2 compressor is too big for the base plate for either a fresh-air or 6 barrel set up. I was toying with one of the later model rotary compressors, but that seems to create a very busy engine compartment. I could have swore I once saw a '70 Challenger at a show a long time ago that has a compressor under the alternator. This was facilitated with the use of an electric fuel pump and the elimination of the mechanical pump. I think this would be a very cool combination on a '70 Road Runner.
Ideas?
Troy
Houston Mopar Connection Club
Re: Air conditioning compressor ideas [Re: hemi68charger] #2479095
04/07/18 10:30 PM
04/07/18 10:30 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: Air conditioning compressor ideas [Re: hemi68charger] #2479128
04/07/18 11:08 PM
04/07/18 11:08 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the Sanden, with factory style hoses with R134a compatible rubber hose upgrade, will freeze you out.
Re: Air conditioning compressor ideas [Re: hemi68charger] #2479173
04/08/18 12:44 AM
04/08/18 12:44 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Troy,years ago Direct Connection had this air cleaner available to cleared the RV2 compressor,still have it.
Re: Air conditioning compressor ideas [Re: hemi68charger] #2479267
04/08/18 09:57 AM
04/08/18 09:57 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we make a serpentine belt kit that move the alternator up where the ac compressor goes and the ac compressor down where the alternator was. we also have an ultra low mount kit in the works that put the ac under the alternator. check out our facebook page and website.
kits prices what changed, complete kit with all accessories start about $1000 including all accessories
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Air conditioning compressor ideas [Re: 62maxwgn] #2479938
04/09/18 12:55 PM
04/09/18 12:55 PM
Houston, Tx
Houston, Tx
Thanks all.........
Hey there Bill,
Thanks for the reply... Let me think if I want the compressor on top or hidden under the alternator...
Hope you've been well..........
Troy
Troy
Re: Air conditioning compressor ideas [Re: hemi68charger] #2479951
04/09/18 01:16 PM
04/09/18 01:16 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I too run a triple black six pack and aftermarket A/C. I used the Bouchillon under alternator bracket, but modified it to change the belt paths to gain more belt wrap around the pulleys.
The new routing uses one belt from the crank to the A/C compressor, and a separate belt from the A/C compressor to the beefed up CS140 alternator. My power steering belt goes from the crank to the water pump and then to the power steering pump.
Most people never know it has A/C while looking under the hood.
Re: Air conditioning compressor ideas [Re: hemi68charger] #2480116
04/09/18 06:10 PM
04/09/18 06:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The under alternator mounts are pretty slick. Saw one where the guy did such a nice job of routing his aftermarket hoses that you had to look close before noticing the car had a/c.
Re: Air conditioning compressor ideas [Re: hemi68charger] #2480406
04/10/18 11:43 AM
04/10/18 11:43 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I also want to put new style a.c. on 71 440 6 pack charger.(clone) I don't want anything up front on top of the motor. Want it bolted down under the alt. Don't know which sanden pump to use
Will be using a v belt style. And if I can't find a bracket setup I like il make my own
I don't want to see the pump at all
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Air conditioning compressor ideas [Re: hemi68charger] #2480434
04/10/18 12:30 PM
04/10/18 12:30 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Anybody ever tried one of these? Jeg's electric A/C compressor?
http://www.jegs.com/webapp/wcs/stores/se...p;storeId=10001
Re: Air conditioning compressor ideas [Re: toplescuda] #2480457
04/10/18 01:14 PM
04/10/18 01:14 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The Sanden compressor is nicknamed "the Shorty". Buschillion carries them. I bought my condenser, receiver dryer and some hardlines used between the two from Nostalgic Air in Florida.
Nostalgic Air has great customer service and tech help, plus their prices are better than most. I also bought my R-134 specific condenser from them. It fills my entire radiator opening, and I sealed it along all the edges, so all the air has to go through it and pass through the radiator.
I used the GenV in car kit from VintageAir. It is a nice kit.
Re: Air conditioning compressor ideas [Re: hemi68charger] #2480689
04/10/18 07:57 PM
04/10/18 07:57 PM
None
71rm23 Offline
71rm23  Offline
None
If not looking for factory, then Sanden and be done.
Re: Air conditioning compressor ideas [Re: hemi68charger] #2480888
04/11/18 01:29 AM
04/11/18 01:29 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I considered the low mount for my car BUT I read several instances where there was extensive belt squeal! The low mount usually means one drive belt. JBC must have known this going in....what other reason would you have 2 belts to drive it?
Re: Air conditioning compressor ideas [Re: Kern Dog] #2481018
04/11/18 12:03 PM
04/11/18 12:03 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
here is an ultra low mount kit we are working on, it should be completing testing in the next month.
https://www.facebook.com/photo.php?fbid=10208340133233229&set=pcb.1345983338748340&type=3
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Air conditioning compressor ideas [Re: hemi68charger] #2481032
04/11/18 12:38 PM
04/11/18 12:38 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Jerry, link did not work for me, Facebook says:
Sorry, this content isn't available right now
Re: Air conditioning compressor ideas [Re: Jerry] #2481045
04/11/18 01:02 PM
04/11/18 01:02 PM
moparx Offline
moparx  Offline
jerry, do you have a link for those of us that don't do facepage ? TIA.
beer
Re: Air conditioning compressor ideas [Re: moparx] #2481141
04/11/18 03:33 PM
04/11/18 03:33 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
here are the two low mount kits we offer. both can be had for about $1000,
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Air conditioning compressor ideas [Re: hemi68charger] #2481217
04/11/18 06:59 PM
04/11/18 06:59 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I did what jbc426 did and bought the bouchillon low mount kit and rerouted the belts and have had no problems going on 6 years now. I even ran a gm based powermaster alt. which works nicely with the kit.
Re: Air conditioning compressor ideas [Re: rapom] #2481343
04/11/18 11:38 PM
04/11/18 11:38 PM
Minnesota
RROD Online content
RROD  Online Content
Minnesota
Did you have to eliminate the mechanical fuel pump? Any squeal issue?
Re: Air conditioning compressor ideas [Re: hemi68charger] #2481412
04/12/18 01:20 AM
04/12/18 01:20 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
for the ultra low mount yes we got rid of the mechanical fuel pump. and there are no squeal issues. the spring loaded tensioner keeps everything playing nicely
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
