Re: Whos wideband, and fuel ratio gauge
[Re: Moparnut426]
#2481010
04/11/18 11:45 AM
04/11/18 11:45 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I have two Innovate LC-2s, I found the best prices on ebay. I didn't buy them at the same time though, if I did that I would have got the unit they have that runs one gauge and 2 sensors. I have had zero trouble from them.
68 Barracuda Formula S 340
[Re: Moparnut426]
#2481020
04/11/18 12:05 PM
04/11/18 12:05 PM
Bad340fish
Tulsa OK
Yeah I ran one on one bank for a long time. I added a second because my EFI can correct bank to bank if I want it to.
[Re: Moparnut426]
#2481564
04/12/18 12:04 PM
04/12/18 12:04 PM
Posts: 304 Florida
Mark Whitener
Innovate LM2. It allows you to read live and log on an SD card.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: Moparnut426]
#2481665
04/12/18 02:50 PM
04/12/18 02:50 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
I just want a simple rich/lean gauge to help in carb tuning
Kasey A gage is fine for tuning a steady condition. By this I mean say you want to know how an adjustment effected the AFR at idle. Or, driving steady on the interstate 65 mph. Or even pedal to the floor, from last shift through the lights. For all that, a gage is good. But if you want to know what happens as the throttle moves, or the car starts to go up a hill, or some more detail, then a logging with other info is a really needed. That way you can see the relationship with rpm at a minimum, and tps, manifold vac, etc if you want. For logging the LM2 like Mark mentioned, or a gage with the pocket logger are pretty good consumer grade options. So all depends on what you mean by tuning and how deep in you think you're going to get. Innovate's stuff is fast, and it has error codes, and can be calibrated. OTH logging software and hardware setups are not the most user friendly.
[Re: Mattax]
#2481865
04/12/18 10:33 PM
04/12/18 10:33 PM
dartman366
Mt. Vernon, Ohio
I use a Innovate LM-2 and love it, I made a mount to hang mine from the dash, so all I have to worry about is remembering to punch the record button at the end of my burn out and just after the finish line so I can record my results.
