Race car wiring - remote water pump #2480294
04/10/18 12:42 AM
04/10/18 12:42 AM
AndyF Offline OP
AndyF  Offline OP
I'll have a remote water pump on the Duster and I'm trying to figure out the best way to wire it. I can wire it to the ACC circuit so it is on whenever the ignition key is on or in ACC. That would allow me to run it with the engine off if I wanted to cool the engine down.
I can wire it to IGN on so it is on when the key is on or the engine is on.
I can also use the EFI system to control it. For instance, I can program the ECU to turn the pump on whenever the engine is running (speed over 500 rpm). If I do it that way then it is a little more fool proof, but I can't turn it on with the engine off.
Does the water pump need to be run when the engine is off? Only reason I can think of is to help cool the engine down between rounds.
Re: Race car wiring - remote water pump [Re: AndyF] #2480297
04/10/18 12:54 AM
04/10/18 12:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You could wire it through the fuel pump relay so
it has enough amps.. that is near the ECU
wave
Re: Race car wiring - remote water pump [Re: AndyF] #2480316
04/10/18 01:33 AM
04/10/18 01:33 AM
Cab_Burge Online work
Cab_Burge  Online Work
One of the local drag racers has a 160F temp. sensor installed in the fins of his radiator so it will turn on and off the water pump at 160F, I'm not sure if he has it wired into the ignition switch or not work
He does commercial appliance repair here in Bend so he may have it set up so he can turn it on with the ignition switch on and have it turn itself off with the ignition switch turned off, I can ask him if you want to know up
Re: Race car wiring - remote water pump [Re: AndyF] #2480317
04/10/18 01:34 AM
04/10/18 01:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For between rounds and to keep the heads cool, I like the water pump & radiator fan to run whether engine's on or off, and I can run them independently of each other. Not sure what you have, I just have the old-school Moroso electric deal with Gilmer belt driving an OEM water pump.
Re: Race car wiring - remote water pump [Re: AndyF] #2480329
04/10/18 02:10 AM
04/10/18 02:10 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Andy my Dart has the water pump relay controlled off the the ACC key switch and the fan on a controller with a temp probe in the tank.
Fan is set up to run when ever it is hot enough to need it. I also run a t-stat.
Lots of ways to do it, this works well for me.
"Just a Bracket car dressed up like a streetcar"
Re: Race car wiring - remote water pump [Re: AndyF] #2480330
04/10/18 02:12 AM
04/10/18 02:12 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I have a remote water pump. I put a pressure switch on the oil system so that as soon as there is oil pressure the water pump runs, to avoid accidental over heating.
Then I also ran a switch in the car that can turn the water pump on when the motor is not running, for between round cooling.
This works well for a bracket car.
If I were you I would use the EFI system.
1974 Roadrunner
1967 Charger
Re: Race car wiring - remote water pump [Re: AndyF] #2480342
04/10/18 03:25 AM
04/10/18 03:25 AM
CA
crackedback Offline
crackedback  Offline
CA
Where you pull power is dependent upon how the car is wired.
If you have a BIG cable running from battery to alternator, grab or provide a bus point from alt charge stud.
If running OEM wiring, there is no good location to run the pump in both engine on or off configurations.
Re: Race car wiring - remote water pump [Re: AndyF] #2480398
04/10/18 11:33 AM
04/10/18 11:33 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Andy I run mine off my ECU. It comes on at at 500RPM OR when the temp is over 120*. My high and low fans are also run by the ECU. When I get done making a pass I shut the engine off and turn the key back on, the fans and pump run until the engine gets down to 120* and then shut off. Makes it easy to manage engine temp without the fear of leaving them on for to long.
68 Barracuda Formula S 340
Re: Race car wiring - remote water pump [Re: AndyF] #2480432
04/10/18 12:24 PM
04/10/18 12:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Since you have the ability, I suggest you drive it with the ECU in pwm mode. This way, you can always have some flow without temp surge.
Re: Race car wiring - remote water pump [Re: AndyF] #2480445
04/10/18 12:46 PM
04/10/18 12:46 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I'd wire it to a relay and have the ECU ground it to turn it on bad on temp, rpm, whatever you like, but then also have a manual override switch that will pull the relay to ground to run the pump with the engine off.
Or this:
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Race car wiring - remote water pump [Re: AndyF] #2480450
04/10/18 01:01 PM
04/10/18 01:01 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Simple rule with water pumps - if the engine is running - the pump must be on - that way you avoid steam pockets or hot spots away from the sensor - Also you should be able to turn it on when not running to cool between rounds - many of the new engines with electric water pump and fan actually can run when the engine is off - this allows for a conrolled cooling cycle to avoid heat soak
Re: Race car wiring - remote water pump [Re: AndyF] #2480468
04/10/18 01:36 PM
04/10/18 01:36 PM
AndyF Offline OP
AndyF  Offline OP
I am setting up a relay panel for the car to control things like the fuel pump, water pump, fans, etc. I will use ground switching as much as possible since it is safer than voltage switching.
I think I can use the ECU to control the pump and I think I can create a digital switch on the digital dash so I can turn the pump on even if the engine isn't running. Might take me a while to figure it all out though. Lots of new stuff to learn.........
Re: Race car wiring - remote water pump [Re: AndyF] #2480494
04/10/18 02:29 PM
04/10/18 02:29 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Take a look at www.leashelectronics.com - I started using their boards - have them in both cars - made wiring very clean
Re: Race car wiring - remote water pump [Re: AndyF] #2480507
04/10/18 02:54 PM
04/10/18 02:54 PM
AndyF Offline OP
AndyF  Offline OP
Thanks, I'll take a look at that. I've been looking around for integrated solutions like that. I was thinking of going with the relay board from Auto Rod Controls but I'll take a look at Leash.
Re: Race car wiring - remote water pump [Re: Bad340fish] #2480511
04/10/18 02:58 PM
04/10/18 02:58 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
This is how I would do it with EFI...
Re: Race car wiring - remote water pump [Re: AndyF] #2480561
04/10/18 04:30 PM
04/10/18 04:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use a few of his relay boards for different things, nice stuff. Really nice product for the money.
Re: Race car wiring - remote water pump [Re: Forest] #2480574
04/10/18 04:47 PM
04/10/18 04:47 PM
AndyF Offline OP
AndyF  Offline OP
Yeah that is kind of what I'm thinking too. I can also do the same trick with the transmission cooler. I have a sensor in the pan so the ECU can turn the fan on and off based on temp. The fluid doesn't move of course unless the pump is turning but I can still cool down the fluid that is in the cooler. The fuel pump is already controlled by the ECU with EFI so that is taken care of also. The car starts to get fairly automated at that point. I originally was going to put a switch panel in the car but now I've decided that I can get rid of the switch panel all together so I'll probably put it up for sale.
Re: Race car wiring - remote water pump [Re: AndyF] #2480586
04/10/18 05:03 PM
04/10/18 05:03 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yeah the Megasquirt really automated mine also. I have the factory key, line lock button, and a starter button. Not bad for running two fans, two fuel pumps, and an electric water pump.
Re: Race car wiring - remote water pump [Re: AndyF] #2480590
04/10/18 05:08 PM
04/10/18 05:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess I miss read the post but on a race car I would run it
through the ECU and run the control through it.. I have
run Rampage run through it and a separate over ride on
the fan and pump on a heavy duty relay
wave
Re: Race car wiring - remote water pump [Re: TRENDZ] #2480609
04/10/18 05:36 PM
04/10/18 05:36 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have considered this, I would need to add a solid state relay for the WP in my situation. I normally just run the water pump all the time, but in the winter it makes it hard to get engine temp up over 130 or so. It would be nice to slow it down to help build a little heat.
