Re: Considering new Borgeson box [Re: dangina] #2411892
12/01/17 06:11 PM
12/01/17 06:11 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
DANGINA -- You've stated "My turning radius from lock to lock is about 1.8 turns"... and that's with the longer Fast Ratio pitman arm (and the longer idler arm, I presume, as well). At about 1.8 turns lock-to-lock, that is very, very fast!!!... something I'd love to have for the quickest pylon manuevering! (With my T/A box and longer idler arm as well, I also run a smaller stering wheel.... 11.5" diameter... helps for quicker steering action!... and, of course, a Saginaw ps pump... never run a Federal ps pump!!!).
Question: At that ratio/setup, are the inside of the front tires hitting the frame rail (typically the rear inside of the tire)?
Are you running a BB or SB? I ask because most long arm setups interfere with tubular BB headers (unless some denting is done for clearance, as required).
T/Anks ahead!!
Re: Considering new Borgeson box [Re: JF_Moparts] #2412130
12/02/17 05:00 AM
12/02/17 05:00 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
The fronts don't hit the frame rails as I am running 1" spacers and +15mm enkei rpf1 rims with a 245/45/r18 tire.(I'm also running 2" drop spindles from magnumforce and I have my hotchkis adjustable strut rods maxed out for the most caster, I'm also running hotchkis UCA's, Running a big block setup with hedman 78030 headers - no issues there, but I did have to chop up my headers for the mini starter when I went to the larger flywheel (11" instead of the 10.5") I am running the fast ratio pitman/idler arms.
Re: Considering new Borgeson box [Re: dangina] #2445940
02/03/18 11:36 PM
02/03/18 11:36 PM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
Thanks for the info. Work pulled me away from the car but now it's back on my radar. There's a lot I need to do with it.
I'm 99% sure I'm going with the Borgeson, new pump, and coupler. I'll probably go back to stock pitman/idler but that will depend on if I go with a new TTI setup.
Anyone got any leads on some good Mopar mechanics in the Los Angeles / SFV area?
Thanks.
Re: Considering new Borgeson box [Re: autoxcuda] #2479205
04/08/18 01:43 AM
04/08/18 01:43 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Avoid that U-joint like the plague! Stick with the mod'd pot coupler from Bergman!
RIck
Re: Considering new Borgeson box [Re: JF_Moparts] #2479712
04/08/18 11:58 PM
04/08/18 11:58 PM
Texas
GoodysGotaCuda Online penguin-006
5.7L Hemi, 6spd
GoodysGotaCuda  Online Penguin-006
5.7L Hemi, 6spd
Texas
ujoint seems to be working fine here.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Considering new Borgeson box [Re: GoodysGotaCuda] #2480136
04/09/18 07:16 PM
04/09/18 07:16 PM
South Dakota
W
wireweld Offline
wireweld  Offline
W
South Dakota
My ujoint is working fine too. Been on for 5 years. What is so wrong with it?
Re: Considering new Borgeson box [Re: JF_Moparts] #2480162
04/09/18 08:13 PM
04/09/18 08:13 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Chassis flex can bind it up since the u-joint eliminates the ability to absorb beam bending in the car as a whole. Sub frame connectors go a long way in preventing this.
Re: Considering new Borgeson box [Re: JF_Moparts] #2480396
04/10/18 11:23 AM
04/10/18 11:23 AM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Ujoints on all my cars. No problems. 30k+ miles and god knows how much track time/autocrosses. But I'm sure with all the un-weather protected brake pistons, heims and u joints, one of them will explode any day now.
Re: Considering new Borgeson box [Re: 68rrunner] #2480780
04/10/18 10:22 PM
04/10/18 10:22 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
panic panic panic panic
2020 RAM 1500
