Page 17 of 33 1 2 15 16 17 18 19 32 33
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247981
09/24/11 11:23 PM
09/24/11 11:23 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247982
09/24/11 11:24 PM
09/24/11 11:24 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247983
09/30/11 03:01 PM
09/30/11 03:01 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
car is looking great and all your work continues to appear very nicely done.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247984
10/01/11 02:51 AM
10/01/11 02:51 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Looks great! Were you able to install the aft retention nut on the 340 cuda pin or did you have to drill a holes for access? My hood only has access for the fwd pin.
Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: PROGRESS 1972 340 4spd Cuda [Re: 19cuda73] #247985
10/01/11 12:04 PM
10/01/11 12:04 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks guys, Dennis there's no easy access but I'll figure out how they did it. Maybe a plastic insert? I wondered why my car had a (broken) strange type rivet at the drivers side quarter panel for the vinyl top trim retention instead of the stud type clip. I later saw they miss-aligned it and the holes did not match. I simply opened the inner hole and used the clip, guess the factory had no time for that.
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247986
10/02/11 10:30 PM
10/02/11 10:30 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
My 72 has the V21 hood paint and color keyed grille. Paint and hood was gone off the car when I bought it in 81 but tracked down the original owner, he still had the hood in the rafters of the garage. I bought it and still has nice original paint on it. My car has shaker now. Coming up in Mopar Muscle soon. Cool thread!
Re: PROGRESS 1972 340 4spd Cuda [Re: Hemidavey] #247987
10/03/11 01:37 AM
10/03/11 01:37 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Started to install the wheel well trim
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247988
10/03/11 01:41 AM
10/03/11 01:41 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
body line/contours are off on the pass front. I think the 2 pre-drilled holes were off slightly compared to the bends one is high and the other is low, essentially it needs to rotate clockwise some
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247989
10/03/11 01:44 AM
10/03/11 01:44 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247990
10/03/11 01:54 AM
10/03/11 01:54 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
A little late now but I use sheet metal clecos to hold the trim in the factory holes then clamp the patch panel in to get the panel straight.
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247991
10/03/11 11:53 AM
10/03/11 11:53 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Looks like yours fit similiar to mine. It took some time but I was able to get them to contour in a little better. I didn't use the old holes. Just clamped in place and drilled new holes. Next car I do I will weld up the holes prior to paint. Your doing good keep us posted with pictures.
Dennis
1972 Corvette
Re: PROGRESS 1972 340 4spd Cuda [Re: 19cuda73] #247992
10/05/11 01:34 AM
10/05/11 01:34 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Great attention to detail! This thread is reading more like a resto book than a guy putting together his driver car in a garage. Excellent work!
Re: PROGRESS 1972 340 4spd Cuda [Re: Tom_440] #247993
10/05/11 01:51 PM
10/05/11 01:51 PM
Richmond, VA
rayztoy Online content
rayztoy  Online Content
Richmond, VA
Re: PROGRESS 1972 340 4spd Cuda [Re: rayztoy] #247994
10/05/11 11:41 PM
10/05/11 11:41 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
The antenna was an issue. I ordered the kit from DCS but the bezel forced the antenna at a 45 degree angle. Details are here: the antenna thread This is the bezel that caused the issue, I believe it is an AAR bezel
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247995
10/05/11 11:43 PM
10/05/11 11:43 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Installed
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247996
10/05/11 11:46 PM
10/05/11 11:46 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
New bezel
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247997
10/05/11 11:48 PM
10/05/11 11:48 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Installed, and things are much straighter. Reflection is pretty clear huh?
Re: PROGRESS 1972 340 4spd Cuda [Re: UCUDANT] #247998
10/06/11 02:14 PM
10/06/11 02:14 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I think you are right on the bezel. The first one looks like my T/A one. The top came out great, you did a really nice job on it. Keep the progress reports coming. You are making super progress on it.
Joe
65 Barracuda
70 Challenger
Re: PROGRESS 1972 340 4spd Cuda [Re: jrwoodjoe] #247999
10/08/11 11:32 PM
10/08/11 11:32 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Just a shot from a few days ago....
Re: PROGRESS 1972 340 4spd Cuda [Re: rayztoy] #248000
10/20/11 11:03 PM
10/20/11 11:03 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
I had some put into aerosol cans
Nice work on the center caps! Who put the argent into aerosol cans for you? TIA
Ray
Totally Auto has the correct dark argent in a can....
