Re: it's been a while... do i need to oil prime the engine? [Re: Cab_Burge] #2478193
04/06/18 05:12 AM
04/06/18 05:12 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
What about an electric remote pump?
http://www.proweldperformanceparts.com/id93.html
Re: it's been a while... do i need to oil prime the engine? [Re: Cudaful] #2478258
04/06/18 11:42 AM
04/06/18 11:42 AM
PA
Cudaful Offline
Cudaful  Offline
PA
Yup and a lot less compression when there's no fuel mixture firing off pressing against the pistons/bearings. I've taken engines apart and there was still oil on the bearings and cylinder walls. To each his own.
Re: it's been a while... do i need to oil prime the engine? [Re: RapidRobert] #2478558
04/06/18 11:29 PM
04/06/18 11:29 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Originally Posted By RapidRobert
Has anybody thought about installing an oil accumulator?
I think that is a good plan tho not sure how it would hold psi over time. I'm thinking it is very helpful on the stock car in the turns if the pickup gets uncovered (I need a wider pan). It would be an unsightful addition if that is a concern/bothersome.
These have a shut off valve that holds the pressure. It literally is a manual ball valve. Same thing they use on farms for irrigation lines or even your water faucet. These tanks hold something like 3 quarts of oil and when you open the valve, it pre-lubes the engine. Then you start the engine and it uses the oil pressure to refill it, and before you shut the car off, close the valve if you plan on letting it set for a while before driving it again. It its only going to set for a couple days, leave it open. There not that big overall, but I could see in something like an early A-body maybe a bit tight.
Re: it's been a while... do i need to oil prime the engine? [Re: Damned67] #2478587
04/07/18 12:06 AM
04/07/18 12:06 AM
P
Porter67 Offline
Porter67  Offline
P
Just start it.
Re: it's been a while... do i need to oil prime the engine? [Re: Porter67] #2478627
04/07/18 01:17 AM
04/07/18 01:17 AM
Alberta
440_Offroader Offline
Alberta
Exactly. I've taken engines apart from farm trucks, motorhomes, etc. They sit for years sometimes before starting. Owners will just crank until it starts. The bearings will look fine. Some oil will be retained on all the bearings. Crank it until it gets fuel to the carb, by then you should have primed the oil system.
I've just cranked my 383 Challenger over until it starts for 20 years and it still runs fine. It sits for 6 to 8 months a year.
Re: it's been a while... do i need to oil prime the engine? [Re: Damned67] #2478699
04/07/18 06:10 AM
04/07/18 06:10 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Just cranking an engine that has sat for long time....is enough to for the engine to get oil pressure....the oil light in my cars goes out almost immediately. The ones w gauges show pressure just as fast.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: it's been a while... do i need to oil prime the engine? [Re: HemiRick] #2479077
04/07/18 10:01 PM
04/07/18 10:01 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
My Imperial, my Super Bee, my Ram 350; I've owned them all for 20+ years. All sit for months (3, 6, 12, 24) without being started, and I do nothing other than start them and go. The longest each of them had sat without being started has been 5+ years. Start and go. They are all stock engines, ranging from 70,000 miles to 150,000 original engines with no rebuilds. I just drove the Super Bee on a 7-hour road trip to Hodge Restorations and back. I use the truck every 8-months to go haul something or move something to or from storage. The Imperial gets driven once a month or every two months for an hour or two at a time. Start and go. Just sharing what I know! Cheers.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: it's been a while... do i need to oil prime the engine? [Re: Cudaful] #2479302
04/08/18 11:19 AM
04/08/18 11:19 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Originally Posted By Cudaful
I would rather crank mine to get oil pressure first before it fires than have it start right off. Cranking compression is a lot less than running compression and a lot easier on the components. I used to try and get it running as soon as possible after sitting but the lifters always clattered and sometimes didn't pump up even after running for a while. Since I've been cranking it until the oil gauge starts to read, I've never had another noisy lifter again. Those that say it gets oil pressure quicker are right but only because it's spinning faster and it takes the same revolutions to get it primed whether running or cranking.
twocents
The real worry is the cam / lifter interface. (Assuming non-roller). That's why cranking is bad, and instant starting is good. At low RPM there's little or no hydrodynamic wedge of oil on these sliding surfaces -- this is what wipes cams. That surface is splash only, not pressure-fed.
Ether it, bring revs to 2500 immediately.
The factory never pre-lubed any engine. Assembly lube they used: Motor oil.
Rick
