Hello Moparts community,
I attempted to install a stock steering wheel back onto the steering column. I had the keyed slot lined up but there seemed to be some resistance. All of the splines are in good shape.
My question is: how much (if any) is the steering column shaft nut relied upon as to drawing the steering wheel onto the shaft? How much force? Torque? I don't want to jam on that nut forcing the wheel on only to find out that there was an error and causing damage to the threads.
I sure have removed a few steering wheels in the past 5 years or so, but never re-installing over that span. And as a steering wheel puller is required to remove one, I was just wondering if the same force is required to put it back on.
The application in question is a 1968 B Body steering column auto on the floor.
Thanks in advance.
