1968 B Body steering wheel install. #2478659
04/07/18 02:23 AM
04/07/18 02:23 AM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
Hello Moparts community,
I attempted to install a stock steering wheel back onto the steering column. I had the keyed slot lined up but there seemed to be some resistance. All of the splines are in good shape.
My question is: how much (if any) is the steering column shaft nut relied upon as to drawing the steering wheel onto the shaft? How much force? Torque? I don't want to jam on that nut forcing the wheel on only to find out that there was an error and causing damage to the threads.
I sure have removed a few steering wheels in the past 5 years or so, but never re-installing over that span. And as a steering wheel puller is required to remove one, I was just wondering if the same force is required to put it back on.
The application in question is a 1968 B Body steering column auto on the floor.
Thanks in advance. beer
Re: 1968 B Body steering wheel install. [Re: VegasCharger] #2478671
04/07/18 03:18 AM
04/07/18 03:18 AM
if everything is copacetic/square with a visual I would start to draw it on with the nut & see how it goes but I'd sure think it would go on at least partway as is. close up look see for any burrs/nicks etc.
Re: 1968 B Body steering wheel install. [Re: VegasCharger] #2478695
04/07/18 05:50 AM
04/07/18 05:50 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
They should mostly seat without the nut.....if you're having to force it something is not right.....getting them off is sometimes a task but I've never had a problem putting one back on. Its a tapered spline w a master spline, it should just go on if everything is right.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 1968 B Body steering wheel install. [Re: VegasCharger] #2478892
04/07/18 04:00 PM
04/07/18 04:00 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Wire brush shaft end and a smidgen of anti seize should help.
Re: 1968 B Body steering wheel install. [Re: HemiRick] #2479201
04/08/18 01:37 AM
04/08/18 01:37 AM
Rick is right, it should slide right on there.
Re: 1968 B Body steering wheel install. [Re: VegasCharger] #2479262
04/08/18 09:41 AM
04/08/18 09:41 AM
Akron, Ohio
Akron, Ohio
Robert, Rick & srt thanks for your tips.
I cleaned it up some using a small triangle shaped file on the grooves at the keyed area and a few to each side of the key. There seemed to be a very slight burr but nothing major. Afterwards it did go on but not fully seated w/o using the nut to draw it in more. I still think there's a slight hangup and will look into it further.
However your tips and insights help from not going at it with the wrong approach.
Thanks again. beer
