Rick's G3 Project #2479252
04/08/18 08:33 AM
04/08/18 08:33 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Warning there is truck content.
One thing is for sure @ a max weight of 3200LBS it'll be fun.
Got stuck with a 374 CI 5.7 Base short block I built, figured toss it in here and have some fun.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2479248/ramcharger.html#Post2479248
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Rick's G3 Project [Re: ric3xrt] #2479256
04/08/18 08:56 AM
04/08/18 08:56 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I can hardly wait to see that one progress. Cool project!
SuperBeast
An enforcer for the Mopar Mafia!
Re: Rick's G3 Project [Re: ric3xrt] #2497465
05/18/18 09:35 AM
05/18/18 09:35 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
have the headers worked out now, the LX body headers will work with some mods, have to cut the port flange off and remove about a 1/2 inch and move the pipes in towards the head. Flanges are ordered and I'll get some photos up by next week.
Ordered Dropped spindles and van Lower control arms last week, also got brackets to convert the front calipers over to GM 52 style.
Re: Rick's G3 Project [Re: ric3xrt] #2502586
05/31/18 09:35 AM
05/31/18 09:35 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
sold the 374 last night, Gave up trying to sell the 4 in bore 5.7 Pistons, sooooooooooooooo I'm going to use them and build a 410.
These are areal deep dish, but With the Eagle heads should bring compression up in to the mid 9s, good enough for this "street" project
Re: Rick's G3 Project [Re: ric3xrt] #2502858
05/31/18 07:46 PM
05/31/18 07:46 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Have you taken a 5.7,out that much before? I know there’s rumor that the really early 5.7’s are supposed to be a thicker casting
Re: Rick's G3 Project [Re: ric3xrt] #2503401
06/01/18 11:42 PM
06/01/18 11:42 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
The 374 I just sold was a 4in bored 08 block(with a modified 6.4 crank)
I' ve gone as big as 4.09 but that block's original bores were spot on center to start with, but I've had one crack @ 4.08
I wouldn't fear taking any 03-08 5.7 block out to 4in
Anything over 4.0 have it sonic checked and go from there.
Arrington has been doing 4in bore block builds for a few years now, and Nutter racing has been doing 6.1 4.055 bore) 5.7s .My niece Caroline's 05 300srt daily has had 370(4.055) bore 5.7 in it since 08,one of her late boyfriend's 1st builds 10 years and over 140k on that engine, and she's not nice to it.
Attached (only ment to attach 1 photo) is a cross cut of an 05 5.7 block that was stock bore, it's a THICK bore for the record it measures out to be .034-.04
The Eagle blocks are only good for a .03 over bore
Re: Rick's G3 Project [Re: ric3xrt] #2511244
06/21/18 10:27 AM
06/21/18 10:27 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
My rods for the the 410 Build came in last week, worked on the Driver's side header a bit the other night, had to cut the LX headers up to get them to fit between the rails and the block
Re: Rick's G3 Project [Re: ric3xrt] #2511446
06/21/18 06:48 PM
06/21/18 06:48 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I'm Interested in the room you will have to complete the headers.
I have W9 436 cid that I will be doing the same.
Keep the photos coming.
Matt
