WHERE TO BUY A GOOD....... #2479088
04/07/18 10:14 PM
04/07/18 10:14 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Torsion bar remover. Ebay shows all kinds of things that look like a micrometer.
Thanks in advance
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479110
04/07/18 10:48 PM
04/07/18 10:48 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
JB Rhinehart, Realist
A-Body's RULE!
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479118
04/07/18 10:57 PM
04/07/18 10:57 PM
CA
crackedback Offline
crackedback  Offline
CA
You can make one pretty easily if you have a drill and piece of flat plate steel and some u-clamps from a hardware store. Remove them all the time with no damage.
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479120
04/07/18 11:01 PM
04/07/18 11:01 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479138
04/07/18 11:19 PM
04/07/18 11:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The ones that look like a "micrometer" are used for Chevy trucks to unload the tension off the bar. There are plenty of examples of homemade tools on the google search for "mopar" specific T-bars.
The Mancini one looks good though shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479143
04/07/18 11:29 PM
04/07/18 11:29 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Never needed one - loosen the lca pin and strut rod and use a bj fork btwn the the K and the LCA. Easy - peasy..
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479170
04/08/18 12:39 AM
04/08/18 12:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Very seldom use it but nice to have .
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479242
04/08/18 07:10 AM
04/08/18 07:10 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I've never used one either....the whole idea is to not hurt the surface of the bar....many ways to grap one w/o hurting it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: WHERE TO BUY A GOOD....... [Re: HemiRick] #2479282
04/08/18 10:48 AM
04/08/18 10:48 AM
what works for me is to take off the wheels to lighten the assy & pry or tap the LCA rearward a bit to get the bar started rearward then tap the LCA forward till it comes off of the bar. A floor jack under the LCA to get it all supported/inline. If I was to clamp it I would ABSOLUTELY use some wood.
Re: WHERE TO BUY A GOOD....... [Re: RapidRobert] #2479329
04/08/18 12:15 PM
04/08/18 12:15 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
This is how I do it too. It works really well, besides, the LCAs have to be loosened to put it all back together.
Re: WHERE TO BUY A GOOD....... [Re: Rhinodart] #2479341
04/08/18 12:35 PM
04/08/18 12:35 PM
Macomb, MI
V
vinnyd76 Offline
vinnyd76  Offline
V
Macomb, MI
Originally Posted By Rhinodart
I purchased the Mancini torsion bar removal tool and it worked well. That was my first time removing torsion bars, so the process went very smoothly with the removal tool.
Re: WHERE TO BUY A GOOD....... [Re: Magnumguy] #2479376
04/08/18 01:15 PM
04/08/18 01:15 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I think I bought it somewhere else, I have the removal tool that Mancini sells. It works well and does not take up much room in the tool box.
Re: WHERE TO BUY A GOOD....... [Re: 340Cuda] #2479498
04/08/18 04:22 PM
04/08/18 04:22 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
If you need to buy the tool,
the http://www.manciniracing.com/tobarreabceb.html
clamp pictured above is the right one.
The home made tool with u bolts werk just fine and does not mar the bar.
It is a heck of a lot cheaper.
I have removed them by releasing the tension in the control arm and tapping on the back of the bar with a drift.
Some times they fight, other times, they fall right out.
I have mechanical Aptitude.
I can screw up anything.
