Performer 318 deep ported or torker II 340
#2478672
04/07/18 03:28 AM
04/07/18 03:28 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
On my 90 ram it appears my only two options for an intake with and offset thermostat housing to clear the a/c compressor are the torker II 340 and the performer 318/360 I haven’t found another intake that will work with the oem air compressor. If you know of one let me know Currently I have the performer bolted on. Ports are 318 sized and it will need a fair amount of work to get it to match the 340 port LA heads along with taking the divider out
A torker II will give me the bigger ports but it’s a single plane intake.
Here is the combo
90 short bed half ton d150 360 unknown compression lets assume 9:1 Cam @ 50 Duration is 232 / 242 (int/exh) Adv. Duration is 298 / 308 (int/exh) Valve Lift is 450 / 475 (int/exh) Lobe Centers 107 / 117 (int/exh) Ported la heads 340/360 port size A518 trans currently has the Stock convertor 8 3/4 clutch sure grip 4.56 gears 30.5” tire Carter comp 625 afb. Headers Cam is not installed yet - being a 2 ton truck I’m thinking about advancing it some.
I’ve heard good things about the torquer II and it’s rpm range lines up with the cam I’m concerned it will kill the lower end.
I’m thinking dial the cam in then move the cam ahead some and stick with the performer. Truck will Likely be 99% daily driven. Future plans are for a higher stall convertor. Your thoughts ?
Re: Performer 318 deep ported or torker II 340
[Re: NTOLERANCE]
#2478674
04/07/18 03:40 AM
04/07/18 03:40 AM
RapidRobert
I'd want the dual plane except for all the work this dual plane would entail. I would try a carb spacer if you have the room & yes adv the cam/dial in the dist. I'm thinking the actual SCR (if OE unrebuilt) might be in the high 7's/the truck is heavy. Here's a BTT for ya.
[Re: NTOLERANCE]
#2478677
04/07/18 03:45 AM
04/07/18 03:45 AM
NTOLERANCE
Madison Wi
Thanks Robert. I should mention I did put a spacer on
It’s not the oe engine. Rebuilt 70’s engine. Heads are ported heavily.
[Re: NTOLERANCE]
#2478824
04/07/18 01:22 PM
04/07/18 01:22 PM
NTOLERANCE
Madison Wi
Thanks for the responses Looks like I’ll stick with my performer and just opened it up
[Re: NTOLERANCE]
#2479154
04/07/18 11:50 PM
04/07/18 11:50 PM
NTOLERANCE
Madison Wi
I’m using the rotary compressor for the a/c. It sits right above the t-stat on other intake manifolds.
The performer and torquer II have the t stat moved to the drivers side for compressor clearance
