418HP 5.9 Magnum #2477523
04/04/18 07:34 PM
04/04/18 07:34 PM
SoCal
Brian Hafliger Offline OP
SoCal
Just finished a customer of ours 5.9 build using our Iron heads, 9.4:1, small OE EFI friendly cam (around 210@ .050), our house 750carb / TTI step headers and Harland Sharp 1.7 rockers...
It made 418HP and 437TQ and idles at 800rpm with just a hint of a note at the tail pipe...
https://youtu.be/yIDG3RITx1A
Brian Hafliger
Re: 418HP 5.9 Magnum [Re: Brian Hafliger] #2477525
04/04/18 07:37 PM
04/04/18 07:37 PM
SoCal
SoCal
Brian Hafliger
Re: 418HP 5.9 Magnum [Re: Brian Hafliger] #2477720
04/05/18 02:56 AM
04/05/18 02:56 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Nice power! What throttle body is it going to run when installed? Is that a Hughes/Edelbrock intake or did you modify an intake?
Re: 418HP 5.9 Magnum [Re: RTSrunner] #2477874
04/05/18 01:32 PM
04/05/18 01:32 PM
SoCal
SoCal
That is the Hughes intake, untouched. I'm not sure which TB he's using, I can find out and let you know.
Brian
Brian Hafliger
Re: 418HP 5.9 Magnum [Re: Brian Hafliger] #2477882
04/05/18 01:41 PM
04/05/18 01:41 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Cool!
Facts are stubborn things.
Re: 418HP 5.9 Magnum [Re: Brian Hafliger] #2477926
04/05/18 02:54 PM
04/05/18 02:54 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
That would be amazing if it would run with the OEM Computer/injection. work
Mo' Farts
Moderated by "tbagger".
Re: 418HP 5.9 Magnum [Re: Grizzly] #2477930
04/05/18 03:01 PM
04/05/18 03:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have bigger cam, cubes and compression and it runs great with the factory injection. About all I did was add 460 ferd fuel infectors.
Re: 418HP 5.9 Magnum [Re: Brian Hafliger] #2478180
04/06/18 02:56 AM
04/06/18 02:56 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
[quote=ou812]That is the Hughes intake, untouched. I'm not sure which TB he's using, I can find out and let you know.
Brian [/quote
Cool,thanks,Nice work on your part to get the numbers.Do you think the EFI will produce similar power levels?
RT
Re: 418HP 5.9 Magnum [Re: RTSrunner] #2478345
04/06/18 03:14 PM
04/06/18 03:14 PM
SoCal
SoCal
Yes I think it will be down a few, but not many.
Brian Hafliger
