Any way to tell what shift a car was built?
#2477546
04/04/18 08:37 PM
04/04/18 08:37 PM
Posts: 4,848 Memphis
HemiRick
Memphis
A b-body in particular....just wondering....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Any way to tell what shift a car was built?
[Re: HemiRick]
#2477664
04/05/18 12:10 AM
04/05/18 12:10 AM
HemiRick
Memphis
OK more than just wondering...there's currently a discussion on FB in the Mopar Collectors Guide closed group about b bodies from Lynch rd and St louis getting dented on the right side of the cowl w a ball peen hammer 1 or 2 times to indicate the shift they were built. Anyone heard this or seen unexplained dents on top of right side of the cowl? there are numerous pics of cars w these dents....
[Re: HemiRick]
#2477676
04/05/18 12:42 AM
04/05/18 12:42 AM
HemiRick
Memphis
I've heard of cigarette butts being commonly found in original engine oil pickups....smoking was not permitted in the engine building plant.
[Re: Dave Hall]
#2477727
04/05/18 03:18 AM
04/05/18 03:18 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
AFAIK there were no cars being built on a third shift (MOPAR musclecar era) I've been working on a number of "ACTUAL Production Date" VS. "SCHEDULED Production Date" calendars from certain years & plants: '69 Lynch Rd. & '70 St. Louis are among them adding the "rumored" shift dent info in the cowl to the mix would help to verify both or either trains of thought how many shifts does it take to assemble a "typical" car?I'll have to get to '70 Lynch Rd. soon - just put an engine in a Superbird - two-dents (need to get a better pic)
[Re: HemiRick]
#2477756
04/05/18 09:23 AM
04/05/18 09:23 AM
Posts: 305 Wisconsin
Big D A12
Wisconsin
We have had significant discussion on this topic over at the A12 forum. The shift theory began many years ago starting from GG. While I used to believe the shift theory was correct, I now respectfully disagree.
To summarize the A12 discussion. These are not shift indicators. They are from a welder. There are two different jaws that were used. A flat type and a round type. I have seen as many as 3 markings on LR cars which quickly debunks the shift theory.
They are visible on vintage LR body in white pictures. The dents are found on both sides at LR and occasionally on the right side at SL. And, SL is mostly just 1 dent on the right side.
As Dan asks above, was a car built in one shift? No, that does not even happen today.
So, to summarize, these are not shift marks. The are from a welder and are part of the manufacturing process, nothing else.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: HemiRick]
#2477876
04/05/18 01:34 PM
04/05/18 01:34 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Quite a few years ago I got a nickle tour of the Ford van assembly plant in Ohio. I think the engineer I was with said it took about 2 days from when the sheet metal was stamped (they stamped the panels at this assembly shop) to when a truck rolled off the line. Once the line starts though, it kept banging them out. I don't recall if this plant only had one shift or two shifts running though.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
