Re: Pro stock tech
[Re: Alan Prusiensky]
#2477736
04/05/18 04:31 AM
04/05/18 04:31 AM
Posts: 275 brisbane,australia
coletrickle
brisbane,australia
If someone can tell me how to upload a picture. I have a racepak run on my phone. I have some early R/D heads and couple of manifolds and the block that won at denver for the first new hemi win,I'm trying to work out how to post some pics?
Re: Pro stock tech
#2477761
04/05/18 09:32 AM
04/05/18 09:32 AM
Posts: 1,756 London, England
Gavin
London, England
Awesome information Alan! In 30+ years of following NHRA I don't think I've heard someone so willing to share information in a Pro class, really interesting info and thanks for coming on Moparts. Keep flying the flag, we'll keep rooting for you!! Also heard your recent interview on WFO radio, good job. (other members, you should check it out if you haven't already)
Re: Pro stock tech
#2478414
04/06/18 05:36 PM
04/06/18 05:36 PM
Posts: 11,733 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I know you're an engine guy, I try to pay attention to what's going on behind the flywheel.
I've been told that teams will cut certain proprietary bars out their old cars before selling them to prevent anyone from knowing their particular configuration. Truth or BS? How much are teams involved in the design of the chassis? Do they have they're own requirements/configurations that they like? Or do they rely on the builder to provide what's best? Do you use a certain amount of flex by design in the chassis or do you try to make it stiff and use suspension adjustments and components for desired changes and control? Between testing and racing, I expect these cars get a lot more laps than people may realize? How many runs will you typically get on a car before it's considered used up and sold?
Re: Pro stock tech
#2479573
04/08/18 07:16 PM
04/08/18 07:16 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I'm looking at upgrading my M/S 3" driveshaft. I have heard from some that the C/F driveshafts have helped with et. Have you found the same results? I wasn't sure how much it would help since the rotational mass is on such a small diameter.
[image][/image]
Re: Pro stock tech
[Re: CMcAllister]
#2479680
04/08/18 11:09 PM
04/08/18 11:09 PM
Posts: 104 New Jersey
Alan Prusiensky
New Jersey
I've been told that teams will cut certain proprietary bars out their old cars before selling them to prevent anyone from knowing their particular configuration. Truth or BS? How much are teams involved in the design of the chassis? Do they have they're own requirements/configurations that they like? Or do they rely on the builder to provide what's best? Do you use a certain amount of flex by design in the chassis or do you try to make it stiff and use suspension adjustments and components for desired changes and control? Between testing and racing, I expect these cars get a lot more laps than people may realize? How many runs will you typically get on a car before it's considered used up and sold? I would say maybe years back somebody like WJ or bob Glidden might cut bars out but nobody would these days. I now Jason and Greg's cars probably have thousands of runs on them. Some teams might have their own way of building a car but mostly Jerry Haas does every car basically the same and they work.
Re: Pro stock tech
[Re: scottb]
#2479686
04/08/18 11:12 PM
04/08/18 11:12 PM
Alan Prusiensky
New Jersey
Alan does Roy J offer any advice on running the hemi motor 2 years back when I came out with the fuel injection Allen helped a little bit but as far as Roy helping with the engine no.If you rely on somebody else you will never figure it out .
Re: Pro stock tech
[Re: fishy340]
#2479688
04/08/18 11:15 PM
04/08/18 11:15 PM
Alan Prusiensky
New Jersey
Thanks Al,curious to know an approximate idea of the lift in a prostock motor and are the cams 70mm ? Are cam is a 78 mm clamshell and its 1.200 in lift.
Re: Pro stock tech
[Re: sgcuda]
#2479689
04/08/18 11:17 PM
04/08/18 11:17 PM
Alan Prusiensky
New Jersey
I'm looking at upgrading my M/S 3" driveshaft. I have heard from some that the C/F driveshafts have helped with et. Have you found the same results? I wasn't sure how much it would help since the rotational mass is on such a small diameter. I don't know of anybody in Pro Stock that runs a carbon fiber driveshaft. Pretty much every driveshaft I've ever seen here is a Mark Williams aluminum driveshaft.
Re: Pro stock tech
[Re: mk_]
#2479714
04/08/18 11:59 PM
04/08/18 11:59 PM
Alan Prusiensky
New Jersey
Not sure if you want to answer this question....... can I ask how much weight is usually on the back tires, and if the left rear is much more than the right rear?
Thanks, Manny 1100 on the rear wheels. I haven't had it on scales for a while so I don't know how much is on each wheel. As far as a Hans I use a rage 3 I'm not even sure if they make that anymore it's actually molded into my seat so I don't even know its back there which I like.
Re: Pro stock tech
[Re: CMcAllister]
#2479717
04/09/18 12:00 AM
04/09/18 12:00 AM
Alan Prusiensky
New Jersey
What's your opinion of 4-wide? the 4wide seems a little confusing to watch but I don't mind it.
Re: Pro stock tech
#2479741
04/09/18 12:36 AM
04/09/18 12:36 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Came by while you were at driver introduction and talked to your dad for awhile..he showed me pictures of your 69 charger his 69 RR...I was passing out ET slips at the time booth for 3 days...LOL
Some people think that job is easy...try it someday at a national event....lol
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Pro stock tech
#2479811
04/09/18 07:13 AM
04/09/18 07:13 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Thanks for starting this thread. I look forward to following it and learning about your race program. Good to know there is still a Mopar presence competing.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
