Who’s 383 stroker kit is the most bang for the buck??? #2476918
04/03/18 06:22 PM
04/03/18 06:22 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
I used 440sources 438 kit before with good results, but now noticed That Mancinis 432 kit has a 4.15” crank vs the 440 sources 3.75” crank. We are pushing a 1969 RR with a 4 speed and 3.55 gears, who’s kit is going to make the most power for this heavy car?? Either way, we plan on using the stealth heads, headers, good ignition system, a voodoo .475-.495 lift Cam matched in rpm to a dual plane intake manifold good for about 1400-5800 rpm range. Thank you moparts!!!!
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2477034
04/03/18 09:04 PM
04/03/18 09:04 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
4.15 stroke may make for some really short pistons. might have oil control issues and want to rock in the bores some. 4.15 should provide more torque than the 3.75, if you like the 3.75 stroke kit before use it again. not a really high revver of a high power engine stopping at 5800 rpm. so the shorter stroke with less problems would get my vote.
does the 4.15 crank use shorter rods?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Jerry] #2477039
04/03/18 09:10 PM
04/03/18 09:10 PM
Hermiston Oregon
Hermiston Oregon
No, both kits use a 6.76 rod
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2477110
04/03/18 11:11 PM
04/03/18 11:11 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
then I think you will have a short piston with the 4.15 crank.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2477130
04/03/18 11:44 PM
04/03/18 11:44 PM
Hermiston Oregon
Hermiston Oregon
what about muscle motors stroker kit for the 383?
i think it uses a 3.9 stroked crank with a shorter rod and yields 450 cid.
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2477163
04/04/18 12:48 AM
04/04/18 12:48 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Those 4.15 cranks use Mopar rod journals which need the block to be clearanced while the 2.2" BBC journals on the 4.25 crank usually just drop in.
As has been posted the 4.15 crank needs the short 1.112 CH piston with the long rod.
4.25" gives you 489-496 cubes using the 6.535 rod and the 1.320" CH piston.
No replacement for displacement and it's the same price. whistling shruggy
Kevin
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Twostick] #2477165
04/04/18 12:49 AM
04/04/18 12:49 AM
Hermiston Oregon
Hermiston Oregon
Thanks Kevin
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Twostick] #2477177
04/04/18 12:59 AM
04/04/18 12:59 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Kevin
iagree
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2477245
04/04/18 08:11 AM
04/04/18 08:11 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I have a 69 383 block here that i'm looking to do something with so i'll keep my eyes post here. coffee
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2477306
04/04/18 11:22 AM
04/04/18 11:22 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would go with the 440 Source 4.250 kit. Mo cubic, mo better. It uses the 2.2 pins that you want and you don't have to deck the block.
2011 Drag Pak Challenger
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2477489
04/04/18 06:36 PM
04/04/18 06:36 PM
Hermiston Oregon
Hermiston Oregon
What about the rod ratio with that kit?
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2478562
04/06/18 11:41 PM
04/06/18 11:41 PM
Nevada
merpar Offline
merpar  Offline
Nevada
I would go with the 3.9 stroke and 6.535 long rods. A really good combo.
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2478798
04/07/18 12:07 PM
04/07/18 12:07 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
David Reher said don't worry about rod ratio.
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2478809
04/07/18 12:39 PM
04/07/18 12:39 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
440 Source with light weight crank....493 cubes
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Dragula] #2478925
04/07/18 05:19 PM
04/07/18 05:19 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
My own:
440 crank offsetground to 3,9"
BBC rods + .250"
Flat top 454 pistons in any size. ? .060 -> 455 c.i.
You need to make valve reliefs in the pistons.
The crank prep is about the same as a 451/470 B stroker combo.
No superlight high $$$ parts here, just pieces to make cheap CI, as is the intention of using a 383 block.
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: mopar_leaner] #2479835
04/09/18 09:09 AM
04/09/18 09:09 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
The big en d width comes with a lot of side plat with the chevy rods....Is it ok to race an engine with so much side play ?
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: rickseeman] #2479966
04/09/18 01:52 PM
04/09/18 01:52 PM
PA
Harry's Taxi 2 Offline
PA
Bob Glidden, Smokey Y, The Grump, GM/Ford/Chrysler engineering all seem to think rod ratio is a fairly important factor.....and more than just a connection for the piston to the crank.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Wedgeman] #2480054
04/09/18 04:01 PM
04/09/18 04:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
Of course it is up To many keyboard racers focus on the wrong things on race motors down
I've raced NHRA Stock, S/ST,S/G , I've built my own blue printed motors and helped several other former NHRA World champions on there Mopar cars engine builds, rod side clearances can be close or loose and the motor will still perform the same on the dyno or at the track shruggy
I've seen ONE stock Mopar V8 motor that had near the minimum Mopar FSM recommended rod side clearances, it was a early production 1966 street Hemi motor that had less than .016 on all the rods, I've also seen as much as .042 side clearances on 318 motors shruggy
My first pump gas 400 block stroker build with BB Chevy rods had from .052 to .039 side clearances, it ran fine, didn't use oil and revved like a SB did grin I shifted it between 7000 and 7800 RPM with no issues ever work
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Harry's Taxi 2] #2480066
04/09/18 04:27 PM
04/09/18 04:27 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
4.25 stroke with a 6.535 rod is still a slightly better rod ratio than a stock 454 BBC.
Kevin
Re: Who’s 383 stroker kit is the most bang for the buck??? [Re: Cab_Burge] #2480528
04/10/18 03:19 PM
04/10/18 03:19 PM
W
Wedgeman Offline
Wedgeman  Offline
W
Cab....
I just took my 440 crank to the shop and the side play would be a total of .065 to .070...is this getting way too much ??
