six pack carb question #2476592
04/03/18 01:16 AM
04/03/18 01:16 AM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
I am building a 6 pack induction system, and was looking at the Holley polished carbs.
30683 and 30684 part numbers.
My question is with fitment on the 6bbl intake...these carbs say chevy, and are a different part number than the mopar carbs.
Anybody know if I will have some issues with fitment?
Thanks,
Re: six pack carb question [Re: Tommy383] #2476600
04/03/18 01:37 AM
04/03/18 01:37 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Plenty, the fuel inlets are on the wrong side for starters. You can run them on a Mopar but it's going to take some non Mopar fuel lines and other associated linkage parts. My advice? find some Mopar versions and save yourself the headaches.
Re: six pack carb question [Re: Tommy383] #2476601
04/03/18 01:40 AM
04/03/18 01:40 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
A few things, Those carbs are mechanical not vacuum, fuel inlet on the drivers side I believe and chevy linkage. Will bolt up to six pack intake and can be made to work.
The only Carbs I care about are under the hood!
Re: six pack carb question [Re: ScottSmith_Harms] #2476631
04/03/18 03:08 AM
04/03/18 03:08 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
iagree
Re: six pack carb question [Re: Morty426] #2476667
04/03/18 10:25 AM
04/03/18 10:25 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The outer carbs have metering blocks instead of metering plates. The rear one will not fit on a mopar intake unless you change to a side hung float bowl.
Re: six pack carb question [Re: Morty426] #2476668
04/03/18 10:27 AM
04/03/18 10:27 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
They are similar to these old Direct Connection mechanical secondary carbs other than the bowls and all have accelerator pumps.
Re: six pack carb question [Re: 62maxwgn] #2476723
04/03/18 12:40 PM
04/03/18 12:40 PM
GomangoCuda Offline
GomangoCuda  Offline
Here is the outer carb. Bowl will not work on rear carb. Also venturi and throttle bore are smaller than mopar type carbs. Booster is also the type commonly found in smaller carbs. Hmm, it has an air horn that might interfere with a mopar aircleaner lid. Center carb linkage will not be compatible with mopar throttle pressure linkage. These are not at all the same as the 4782/4783 aftermarket mechanicals pictured above.
Re: six pack carb question [Re: Tommy383] #2476806
04/03/18 03:32 PM
04/03/18 03:32 PM
Chicago
PurpleBeeper Offline
Chicago
Uh, yeah....what these guys said. Find some Mopar carbs.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
