fuel boiling #2476457
04/02/18 09:27 PM
04/02/18 09:27 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
took the car out thursday stuck in traffic. temp outside was 80 and it started acting stupid. engine temp was only 175. finally got it home and the fuel looked like it was boiling right out the squirters. I have a 1" phenolic spacer on it. is wood better. what are you using to put over the fuel line to insulate it.
Re: fuel boiling [Re: plycuda] #2476464
04/02/18 09:34 PM
04/02/18 09:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The fuel was boiling basically due to it being
winter time fuel(left over when you put it away)
wave
Re: fuel boiling [Re: MR_P_BODY] #2476483
04/02/18 09:59 PM
04/02/18 09:59 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I just filled it up at the gas station. I've driven it a few times in the last month. I don't know when they switch to summer gas
Re: fuel boiling [Re: plycuda] #2476511
04/02/18 10:46 PM
04/02/18 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you ever wonder why it did it on the warmest
day.. its still winter fuel and it will show
up a lot easier with winter fuel
wave
Re: fuel boiling [Re: plycuda] #2476541
04/02/18 11:47 PM
04/02/18 11:47 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Go on to your states website and find out when they stop with the winter oxygenation. Its different among most of the states. Then you have to wonder when they empty the storage tanks and start supplying summer blend fuels. Usually the 93 octane is the last to be changed over due to its lower volume of sales.
Re: fuel boiling [Re: A/MP] #2476589
04/03/18 01:08 AM
04/03/18 01:08 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
There's actually two dates. One for the distributors and a later date for the retailers to be fully switched over.
from 2013 https://www.eia.gov/todayinenergy/detail.php?id=11031
but looks like its still valid.
https://www.caranddriver.com/news/the-vapor-rub-summer-versus-winter-gasoline-explained
The winter fuel RVP is a culprit in the warm early spring weather vapor lock.
What to do about Winter fuel in the summer?
Re: fuel boiling [Re: MR_P_BODY] #2477237
04/04/18 04:37 AM
04/04/18 04:37 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
wave
Mr P is dead right. In Md where I live they switch to summer fuel around mid April and the winter crap will boil at a lower temp. I use a phenolic spacer also and have no trouble in the summer on summer 92 pump. I have heard the wood spacers are very good but don't know if they are better then the phenolic ? Good luck , Ron
