tranny noise
#2476402
04/02/18 08:45 PM
04/02/18 08:45 PM
Posts: 2,263 ILLINOIS
volaredon
ILLINOIS
518 in a 92 Dakota, 1500 miles on a complete overhaul 100% stock, no shift kit, fresh reman T converter. It whines like an old Powerglide, just started this today. Park/Neutral it whines, goes away in gear. Never heard such a whine like this, from a RWD Dodge trans of any kind, and I have been around a bunch of them. was quiet for 1st 1450 miles of it being in truck. ATF+4 fluid, was at "add" mark, added 1/2 qt to full mark, no change. Shifts fine.
What gives?
Re: tranny noise
[Re: volaredon]
#2476863
04/03/18 04:39 PM
04/03/18 04:39 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The whining is usually caused by a rapidly cycling pressure regulator valve; more of an annoyance than a real problem. The factory recommended fix is to replace the valve body.
