Adjusting a McCleod Clutch with a Lakewood Scatter shield? #2475592
04/01/18 08:55 PM
04/01/18 08:55 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, so I usually adjust my clutches by pulling the inspection cover and use a feeler gauge to set the disc gap.
I just installed a new clutch & pressure plate and swapped the stock bell housing for a Lakewood scatter shield with the block plate which covers everything so no access to the disc to check. How are you Lakewood owners making your adjustments>
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2475603
04/01/18 09:12 PM
04/01/18 09:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
I drilled a 1/2 inch hole in the bottom of the last single piece scatter shield I had aligned with the tranny side of the flywheel work scope That worked well for using the feeler gauge up
I ended deciding to adjust the free travel on the clutch pedal so it had about 1/4 to 3/8 inch free play all the way up with it all the way out and that allowed me to speed shift the slick and pro shifted drag racing tranny( a long time ago) very nicely from then on wrench scope
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2475611
04/01/18 09:26 PM
04/01/18 09:26 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
make up a feeler gauge brazed/welded on a long metal rod to fit inside the clutch fork opening. I used a .080 piece of sheet metal welded on an 1/8 welding rod for power shifting a pro/slick shifted 833. A street car can probably get by with less. It will take 2 people since I'm guessing you don't have a removable transmission cover.
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2475612
04/01/18 09:28 PM
04/01/18 09:28 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You could send your Lakewood shield to Chris Hyatt. He can add a window and recert. for you.
[image][/image]
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: sgcuda] #2475621
04/01/18 09:55 PM
04/01/18 09:55 PM
Ohio
lockjaw-express Offline
Ohio
Chris Hyatt did mine, and it was very reasonable.
I did not have it certified, as I don't race much.
A couple of pics of the access hole/cover.
Mark
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2475632
04/01/18 10:14 PM
04/01/18 10:14 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I drilled a hole in the back of mine on the passenger side of the trans. Welded a elen head socket to a long 3/8 extension. Wrote on the bottom of the Bell housing the timing marks I need to align to adjust it the clutch. Worked good.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2475686
04/01/18 11:44 PM
04/01/18 11:44 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I drilled a 1" hole using a hole saw in the bottom of my lakewood, checked it only a couple times. Wast of time in my opinion. I adjust the peddle so the pressure plate starts to engage about a 1" off the floor.
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2475710
04/02/18 12:27 AM
04/02/18 12:27 AM
Washington
madscientist Offline
Washington
If your setting air gap, don't bother.
Set the pedal with an inch of free play and you'll be golden. If you don't ride the clutch, you can use half an inch.
I haven't set air gap since 1980.
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: lockjaw-express] #2475781
04/02/18 01:17 AM
04/02/18 01:17 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Lockjaw....Nice clutch!
Thanks for all of your input guys. Its a street car but I might take it to the track on occasion which is why I may send it out to have a window put in and have it re-certified. For now I guess I'll just try the 1.00 pedal free play route.
On another note I have to say, these Lakewoods could have used a little more finishing concerning engineering and fitment. I've had to grind on some flange areas to get the Z-bar pivot mount to fit flush, drill a hole and grind away material for the clutch return spring, and am still not convinced that the clutch fork pivot is properly located using the stock bolt in bracket.Have any of you used the adjustable fork pivot that Lakewood makes? Any other helpful input on properly aligning the Z-bar and other linkage? This is a 71 Demon, stock 340 block with TTI headers, mini starter, stock style 4 speed transmission with the small bearing retainer using the Lakewood supplied spacer ring to fill the hole.
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2475869
04/02/18 09:03 AM
04/02/18 09:03 AM
sgcuda Offline
sgcuda  Offline
Not a lot of options out there besides Lakewood and Quicktime, which are both owned by the same company. I have had many cars with Lakewood shields in them. The Z bar is never in perfect alignment. The adjustable clutch pivot is for a Ford, maybe a Chevy setup. I have never found an aftermarket fork for a Mopar, and I never really tried to retrofit with one of the others, although it has crossed my mind. There are no replacement Mopar clutch forks out there. The earlier bracket designs were already riveted in, that was fun! You will really enjoy trying to get the shield in and out once the headers and exhaust are all bolted in.
[image][/image]
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: sgcuda] #2476118
04/02/18 02:37 PM
04/02/18 02:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well the good news is that I have it in (for about the 5th time) due to the required bearing hole alignment process, yea, big fun with the TTi's (have I ever said I hate headers? Well, for the record, I DO!).
So the clutch is bolted ion, shield and plate are bolted in, starter is installed (Now THAT was fun!). So the heavy lifting is over for now unless I hit another roadblock getting the clutch fork working properly. It looks ok so far but I'll learn more when I stab the transmission in later today.... Stay tuned.
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2476142
04/02/18 03:00 PM
04/02/18 03:00 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
You may need to space the fork pivot forward a little. Depends on the finger height of the pressure plate. If the fork angle looks wrong then a 1/4" to 3/8" thick spacer might be needed.
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2476191
04/02/18 04:33 PM
04/02/18 04:33 PM
Ohio
Ohio
The reason that the Lakewood does not line up in a stock car is because it was designed to use their motor mounts...their old motor mounts lift the front of the engine by 3/4”. I have installed two of them, and one engine had the old Lakewood solid motor mounts.
I used Andy’s (AR Engineering) front motorplate, and shim the motorplate by 1/2”, and both the ‘68 Superbee and my ‘69 GTX are right on the money for z-bar installation!!!
I called Lakewood, and they told me that the Bell was designed many years ago, and my experience did not surprise them.
I would rather have a mechanical clutch linkage because I have had problems with Hydraulic TB in the past...they either leak or blow out.
My 2 cents.
Mark
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2476254
04/02/18 07:26 PM
04/02/18 07:26 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
Another thing I forgot to mention: the block saver will be pushed out toward the bottom by the oil pan rubber seal causing the bellhousing to block alignment to be off. You should notch out the area around it so the block saver sits flush against the engine block and not pushed away from it. That is the only way to make it fit correctly as the rubber oil pan seal probably sticks out by 3/8" or so at least that's my experience with every aftermarket bellhousing I've used.
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2476348
04/02/18 08:30 PM
04/02/18 08:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Funny you should mention that. I did noticed that the seal pushed the plate out a bit, made me scratch my head but I figured it would be ok when tightened up. I installed the bell housing with the plate in place and did the front bearing adjustment with it all torqued in place so I'm assuming it will all be ok? It's all bolted up solid now and appears to be ok.....
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2476475
04/02/18 09:51 PM
04/02/18 09:51 PM
sgcuda Offline
sgcuda  Offline
There are 2 different length adjusting rods that go from the Z bar to the fork. 1 is supposed to be A body and the other B/E body. Don't get messed up with Mopar's designation. Sometimes you need the longer one, sometimes you need the shorter one. A sbc rocker pivot ball makes for a great pivot bushing against the fork. Just keep it greased. The nylon and rubber crap that comes in the Mopar kit is a bunch of junk.
[image][/image]
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2477036
04/03/18 09:08 PM
04/03/18 09:08 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
While it may appear to "be ok" it isn't and will not be right until you notch the block saver to fit the oil pan seal. Your car, your parts, but I would never run it that way... Best of luck to you, your gonna need it if you don't fix it right...
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2477100
04/03/18 11:03 PM
04/03/18 11:03 PM
sgcuda Offline
sgcuda  Offline
I had my block plate hit the lifter oil galley plugs. Had to put some holes in plate to clear the plugs.
[image][/image]
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2477191
04/04/18 01:16 AM
04/04/18 01:16 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Update! I have now removed everything back down to the block, starting over after a trip to the machine shop to have the required mods done to this pile of garbage they call a finished "product". I swear it makes me want to design a true bolt on bell housing that actually fits with nothing more than hand tools. What a joke!
Re: Adjusting a McCleod Clutch with a Lakewood Scatter shield? [Re: ScottSmith_Harms] #2477200
04/04/18 01:33 AM
04/04/18 01:33 AM
Washington
Washington
Put me at the top of the list to buy one if you do.
But I doubt you'll sell more than 3 of them. Sticks are going the way of the doo doo bird. Most people under 40 can't even drive a stick.
