why would you want to spend money and time to put that small (35 amps
![down down](/ubbthreads/images/graemlins/custom/down.gif)
) of a amperage rated alternator on your car?
Buy at least as big(45 amp stock on most Mopars, 65 Amps on a lot of the bigger optioned cars with air and so on
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
) or bigger 1 wire alternator
![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
As far as wiring it I can think of two options, one feed it directly to the hot wire on the starter relay on the fenderwell or firewall or run it directly to the + side of the battery and add a volt meter inside the car where you can see it.
You will need to decide what to do about the stock amp gauge and wiring also when ever you convert any Mopar to a single wire alternator, no matter what amps it puts out
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
